[mapserver-users] Oracle layer partially drawn
Geograma
amanero at geograma.com
Wed Sep 3 03:57:18 PDT 2014
Hello Tike,
First, thanks for your help!
- Checked that the layer has all the data (the same records in PostGis and
Oracle).
- DEBUG 5 is on
- Cannot try ORG connection (it gives me an error, I do not know why)
- Scaledoms, transparency, wms_extent and spatial index recreated in Oracle
removed but no change
- The test you suggested:
· Downloaded:
http//www.naturalearthdata.com/download/10m/cultural/ne_10m_populated_places.zip
· Loaded info to Oracle using ogr2ogr -f oci oci:user/pass at orcl
ne_10m_populated_places.shp
· New "NE_10M_POPULATED_PLACES.map", as follows:
MAP
NAME TEST
EXTENT -180 -90 180 90
SYMBOLSET "symbols.sym"
FONTSET "fonts.txt"
DEBUG ON
LEGEND
IMAGECOLOR -1 -1 -1
LABEL
FONT "vera"
ANGLE FOLLOW
COLOR 0 0 0
ENCODING "UTF-8"
TYPE truetype
SIZE 8
END
STATUS ON
TRANSPARENT ON
END
WEB
METADATA
"wms_encoding" "UTF-8"
"wms_title" "WMS"
"wms_abstract" ""
"wms_srs" "epsg:4326 epsg:23030"
"wms_enable_request" "*"
"wms_onlineresource"
"http://v-0049:8080/fcgi-bin/mapserv.exe?map=C:\ms4w\maps\NE_10M_POPULATED_PLACES.map"
labelcache_map_edge_buffer "-10"
END
END
PROJECTION
"init=epsg:4326"
END
CONFIG MS_ERRORFILE "c:\ms4w_3_0_6\maps\logs\NE_10M_POPULATED_PLACES.log"
DEBUG 5
CONFIG "CPL_DEBUG" "ON"
CONFIG "PROJ_DEBUG" "ON"
IMAGECOLOR 153 179 204
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION QUALITY=100
FORMATOPTION "INTERLACE=OFF"
END
LAYER
NAME "NE_10M_POPULATED_PLACES"
STATUS ON
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION "FONDO_2014_06/FONDO_2014_06 at orcl"
DATA "ora_geometry from NE_10M_POPULATED_PLACES using unique ogr_fid
srid 4326"
SIZEUNITS pixels
LABELITEM "name"
PROJECTION
"init=epsg:4326"
END
TYPE truetype
CLASS
STYLE
COLOR 254 0 0
SIZE 1
END
SYMBOL "circle"
NAME "default"
LABEL
FONT "arial"
ANGLE 0
COLOR 0 0 0
TYPE truetype
SIZE 10
POSITION Auto
PARTIALS FALSE
FORCE FALSE
OUTLINECOLOR 254 254 254
END
END
METADATA
"wms_title" "public.smaltown_point_500k"
"wms_abstract" "Capa del Servicio WMS"
#"wms_extent" "-180 -90 180 90"
"wms_layer_group" "/TINSAMaps"
"gml_include_items" "all"
END
PROCESSING "CLOSE_CONNECTION=DEFER"
END # Layer
END # Map File
· Request made:
http://v-0049:8081/fcgi-bin/mapserv.exe?map=C:\ms4w_3_0_6\maps\NE_10M_POPULATED_PLACES.map&LAYERS=NE_10M_POPULATED_PLACES&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FORMAT=image%2Fpng&SRS=EPSG%3A4326&BBOX=-180,-90,180,90&WIDTH=768&HEIGHT=384&d
· Log got:
[Wed Sep 03 12:57:47 2014].724000 CGI Request 1 on process 5764
[Wed Sep 03 12:57:47 2014].740000 msDrawMap(): rendering using outputformat
named png (AGG/PNG).
[Wed Sep 03 12:57:47 2014].740000 msOracleSpatialLayerOpen called with:
ora_geometry from NE_10M_POPULATED_PLACES using unique ogr_fid srid 4326
(Layer pointer 02E88CB8)
[Wed Sep 03 12:57:48 2014].490000 msOracleSpatialLayerOpen. Shared
connection not available. Creating one.
msConnPoolRegister(NE_10M_POPULATED_PLACES,user/pass at orcl,02EB1D08)
[Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerInitItemInfo was
called.
[Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes was
called.
[Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes. Using
this Sql to retrieve the data: SELECT name, ogr_fid,rownum, ora_geometry
FROM NE_10M_POPULATED_PLACES WHERE SDO_FILTER( ora_geometry,
MDSYS.SDO_GEOMETRY(2003, :srid,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates ),'querytype=window') =
'TRUE'
[Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes. Bind
values: srid:4326 minx:-179.765625 miny:-89.765625 maxx:179.765625
maxy:89.765625
[Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes getting
ordinate definition.
[Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes converting
to OCIColl.
[Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes bind by
name and object.
[Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes name and
object now bound.
[Wed Sep 03 12:57:48 2014].896000 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Sep 03 12:57:48 2014].896000 msOracleSpatialLayerClose was called.
Layer: 02E88CB8, Layer name: NE_10M_POPULATED_PLACES. Layer connection:
user/pass at orcl
[Wed Sep 03 12:57:48 2014].896000 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
[Wed Sep 03 12:57:48 2014].896000 msOracleSpatialLayerClose. Release the
Oracle Pool.
msConnPoolRelease(NE_10M_POPULATED_PLACES,user/pass at orcl,02EB1D08)
[Wed Sep 03 12:57:48 2014].896000 msDrawLabelCache():
labelcache_map_edge_buffer = 10
[Wed Sep 03 12:57:49 2014].130000 msOracleSpatialLayerClose was called.
user/pass at orcl
· Image got:
<http://osgeo-org.1560.x6.nabble.com/file/n5159854/NE_10M_POPULATED_PLACES.png>
As you can see, the result is not correct.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Oracle-layer-partially-drawn-tp5159828p5159854.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
