[mapserver-users] Oracle layer partially drawn
Rahkonen Jukka (Tike) jukka.rahkonen at mmmtike.fi
Wed Sep 3 04:29:37 PDT 2014
For minimizing the possibility that it is some projection error, could you do the import again by adding -lco SRID=4326 into the ogr2ogr command? Drop the old table first and delete the corresponding row from ALL_SDO_GEOM_METADATA.
-Jukka-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> bounces at lists.osgeo.org] Puolesta Geograma
> Lähetetty: 3. syyskuuta 2014 13:57
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Oracle layer partially drawn
> Hello Tike,
> First, thanks for your help!
> - Checked that the layer has all the data (the same records in PostGis and
> Oracle).
> - DEBUG 5 is on
> - Cannot try ORG connection (it gives me an error, I do not know why)
> - Scaledoms, transparency, wms_extent and spatial index recreated in Oracle
> removed but no change
> - The test you suggested:
>    · Downloaded:
> http//www.naturalearthdata.com/download/10m/cultural/ne_10m_populated_
> places.zip
>    · Loaded info to Oracle using ogr2ogr -f oci oci:user/pass at orcl
> ne_10m_populated_places.shp
>    · New "NE_10M_POPULATED_PLACES.map", as follows:
> MAP
>    NAME TEST
>    EXTENT -180 -90 180 90
>    SYMBOLSET "symbols.sym"
>    FONTSET "fonts.txt"
>    DEBUG ON
>    LEGEND
>       IMAGECOLOR -1 -1 -1
>       LABEL
>          FONT "vera"
>          ANGLE FOLLOW
>          COLOR 0 0 0
>          ENCODING "UTF-8"
>          TYPE truetype
>          SIZE 8
>       END
>       STATUS ON
>       TRANSPARENT ON
>    END
>    WEB
>       METADATA
>          "wms_encoding" "UTF-8"
>          "wms_title" "WMS"
>          "wms_abstract" ""
>          "wms_srs" "epsg:4326 epsg:23030"
> 		 "wms_enable_request" "*"
>          "wms_onlineresource"
> "http://v-0049:8080/fcgi-
> bin/mapserv.exe?map=C:\ms4w\maps\NE_10M_POPULATED_PLACES.map"
>          labelcache_map_edge_buffer "-10"
>       END
>    END
>    PROJECTION
>       "init=epsg:4326"
>    END
>    CONFIG MS_ERRORFILE
> "c:\ms4w_3_0_6\maps\logs\NE_10M_POPULATED_PLACES.log"
>    DEBUG 5
>    CONFIG "CPL_DEBUG" "ON"
>    CONFIG "PROJ_DEBUG" "ON"
>    IMAGECOLOR 153 179 204
>    OUTPUTFORMAT
> 	  NAME png
> 	  DRIVER "AGG/PNG"
> 	  MIMETYPE "image/png"
> 	  IMAGEMODE RGB
> 	  EXTENSION "png"
> 	  FORMATOPTION QUALITY=100
> 	  FORMATOPTION "INTERLACE=OFF"
>    END
>    LAYER
>       NAME "NE_10M_POPULATED_PLACES"
>       STATUS ON
>       TYPE POINT
>       CONNECTIONTYPE oraclespatial
>       CONNECTION "FONDO_2014_06/FONDO_2014_06 at orcl"
>       DATA "ora_geometry from NE_10M_POPULATED_PLACES using unique
> ogr_fid srid 4326"
>       SIZEUNITS pixels
>       LABELITEM "name"
>       PROJECTION
>          "init=epsg:4326"
>       END
>             TYPE truetype
>       CLASS
>          STYLE
>             COLOR 254 0 0
>             SIZE 1
>          END
>          SYMBOL "circle"
>          NAME "default"
>          LABEL
>             FONT "arial"
>             ANGLE 0
>             COLOR 0 0 0
>             TYPE truetype
>             SIZE 10
>             POSITION Auto
>             PARTIALS FALSE
>             FORCE FALSE
>             OUTLINECOLOR 254 254 254
>          END
> 	  END
>       METADATA
>          "wms_title" "public.smaltown_point_500k"
>          "wms_abstract" "Capa del Servicio WMS"
>          #"wms_extent" "-180 -90 180 90"
>          "wms_layer_group" "/TINSAMaps"
>          "gml_include_items" "all"
>       END
>       PROCESSING "CLOSE_CONNECTION=DEFER"
>    END # Layer
> END # Map File
>    · Request made:
> http://v-0049:8081/fcgi-
> bin/mapserv.exe?map=C:\ms4w_3_0_6\maps\NE_10M_POPULATED_PLACES.m
> ap&LAYERS=NE_10M_POPULATED_PLACES&TRANSPARENT=TRUE&SERVICE=W
> MS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FORMAT=image%2Fpng&SR
> S=EPSG%3A4326&BBOX=-180,-90,180,90&WIDTH=768&HEIGHT=384&d
>    · Log got:
> [Wed Sep 03 12:57:47 2014].724000 CGI Request 1 on process 5764 [Wed Sep
> 03 12:57:47 2014].740000 msDrawMap(): rendering using outputformat named
> png (AGG/PNG).
> [Wed Sep 03 12:57:47 2014].740000 msOracleSpatialLayerOpen called with:
> ora_geometry from NE_10M_POPULATED_PLACES using unique ogr_fid srid
> 4326 (Layer pointer 02E88CB8) [Wed Sep 03 12:57:48 2014].490000
> msOracleSpatialLayerOpen. Shared connection not available. Creating one.
> msConnPoolRegister(NE_10M_POPULATED_PLACES,user/pass at orcl,02EB1D08)
> [Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerFreeItemInfo was
> called.
> [Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerInitItemInfo was
> called.
> [Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes was
> called.
> [Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes. Using
> this Sql to retrieve the data: SELECT name, ogr_fid,rownum, ora_geometry
> FROM NE_10M_POPULATED_PLACES WHERE SDO_FILTER( ora_geometry,
> MDSYS.SDO_GEOMETRY(2003, :srid,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates
> ),'querytype=window') = 'TRUE'
> [Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes. Bind
> values: srid:4326   minx:-179.765625   miny:-89.765625  maxx:179.765625
> maxy:89.765625
> [Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes getting
> ordinate definition.
> converting to OCIColl.
> [Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes bind by
> name and object.
> [Wed Sep 03 12:57:48 2014].505000 msOracleSpatialLayerWhichShapes name
> and object now bound.
> [Wed Sep 03 12:57:48 2014].896000 msOracleSpatialLayerFreeItemInfo was
> called.
> [Wed Sep 03 12:57:48 2014].896000 msOracleSpatialLayerClose was called.
> Layer: 02E88CB8, Layer name: NE_10M_POPULATED_PLACES. Layer
> connection:
> user/pass at orcl
> [Wed Sep 03 12:57:48 2014].896000 msOracleSpatialLayerClose. Cleaning
> layerinfo handlers.
> [Wed Sep 03 12:57:48 2014].896000 msOracleSpatialLayerClose. Release the
> Oracle Pool.
> msConnPoolRelease(NE_10M_POPULATED_PLACES,user/pass at orcl,02EB1D08)
> [Wed Sep 03 12:57:48 2014].896000 msDrawLabelCache():
> labelcache_map_edge_buffer = 10
> [Wed Sep 03 12:57:49 2014].130000 msOracleSpatialLayerClose was called.
> connection:
> user/pass at orcl
>    · Image got:
> <http://osgeo-
> org.1560.x6.nabble.com/file/n5159854/NE_10M_POPULATED_PLACES.png>
> As you can see, the result is not correct.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Oracle-
> layer-partially-drawn-tp5159828p5159854.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users mailing list
