[mapserver-users] how to make symbol rotate with the map?
Oliver Christen
oliver.christen at camptocamp.com
Thu Sep 4 05:28:11 PDT 2014
a bit easier way to do it is to use mapserver substitution to recover
the map angle and calculate the final angle value directly in the
postgres data string :
DATA "geom FROM (SELECT ..., (%map_angle%::float+angle)*-1 AS angle
FROM table
WHERE condition)
as foo USING UNIQUE id USING srid=21781"
METADATA
"default_map_angle" "0"
"map_angle_validation_pattern" "[0-9.\-]*" # for map angle
END
CLASS
STYLE
SYMBOL 'bla.png'
SIZE 120.0
ANGLE [angle]
OFFSET 0 60.000000
END
END
maybe there is an even easier way to do it?
> dear all
> I need to make a symbol rotate with the map, i.e. if my symbol has an
> angle of 45° and the map is rotated by, let say, 10°, the symbol angle
> should be 55° to keep it's orientation relative to the map itself.
> at the moment the only way I see is to dynamically set in my database
> the angle values to be used for the symbol calculated from the angle
> of the map selected by the user (which is totally dynamic, not a
> configured value), and that's horrendously annoying as I would have to
> dynamically set the data value for the given layer so it use the
> dynamically generated angles values.
> is there any other way to make a symbol angle follow the map rotation ?
> thanks for reading
> best regards
> Oliver
Camptocamp SA
Oliver Christen
PSE A, EPFL
CH-1015 Lausanne
www.camptocamp.com
+41 21 619 10 23 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
