[mapserver-users] LAYER example for kernerdensity wanted
thomas bonfort
thomas.bonfort at gmail.com
Mon Sep 29 01:33:42 PDT 2014
Jukka,
The msautotest suite has some heatmap examples you can work from:
https://github.com/mapserver/msautotest/blob/master/gdal/heat.map
thomas
On 29 September 2014 10:17, Rahkonen Jukka (Tike) <jukka.rahkonen at mmmtike.fi
> wrote:
> Hi Thomas,
> I have the newest MS4W on the bottom. Then I have downloaded 32-bit
> GDAL-Mapserver development zip from gisinternals.com
> http://gisinternals.com/sdk/PackageList.aspx?file=release-1600-gdal-mapserver.zip
> and changed the contents of the cgi-bin directory by copying all the .dll
> files from \bin and mapserv.exe from \bin\ms\apps of the gisinternals
> package. I have no idea about how safe this method is or if it works with
> PHP MapScript at all. I have only tried to test new features introduced
> after Mapserver v. 6.2 through WMS.
> It can well be that my trouble with kerneldensity map is caused by some
> mismatch with MS4W and the newer components and therefore I would like to
> see a mapfile that works for someone on some platform with that easily
> available point data.
> -Jukka Rahkonen-
> Thomas RAFFIN wrote:
> Hi,
> Could you tell me how you have install / compile MS 6.5-dev on Windows
> please?
> does it works with Apache and PHP (PHP MapScript) ?
> Thanks,
> Thomas
> Le 27/09/2014 21:51, Rahkonen Jukka (Tike) a écrit :
> Hi,
> I am running MapServer version 6.5-dev on Windows and I suppose it has the support for kerneldensity layers. Could someone show the LAYER part that works with the Natural Earth populated places dataset http://www.naturalearthdata.com/http//www.naturalearthdata.com/download/10m/cultural/ne_10m_populated_places.zip <http://www.naturalearthdata.com/http/www.naturalearthdata.com/download/10m/cultural/ne_10m_populated_places.zip>? I have created .qix index but not touched the data in other ways.
> I have indeed managed to get some coloured stripes out at some scales but what I mostly get is Internal server error (http 500). MS_ERRORFILE does not show any errors and Apache error log is probably recording just this:
> [Sat Sep 27 21:57:27 2014] [error] [client 127.0.0.1] Premature end of script headers: mapserv.exe
> My current LAYER (or layers, one for data and one for kerneldensity):
> LAYER
> NAME "points"
> DATA "c:\data\ne\ne_10m_populated_places"
> TYPE POINT
> STATUS ON
> PROJECTION
> "init=epsg:4326"
> END
> debug 5
> CLASS
> STYLE
> SIZE 5
> SYMBOL "circle"
> COLOR 200 200 200
> OUTLINECOLOR 0 0 0
> END
> END
> END
> layer
> name "heatmap"
> type raster
> connectiontype kerneldensity
> connection "points"
> status on
> debug 5
> #processing "RANGE_COLORSPACE=HSL"
> processing "KERNELDENSITY_RADIUS=20"
> processing "KERNELDENSITY_ATTRIBUTE=RANK_MIN"
> #processing "KERNELDENSITY_COMPUTE_BORDERS=ON"
> processing "KERNELDENSITY_NORMALIZATION=AUTO"
> offsite 0 0 0
> class
> style
> COLORRANGE "#0000ff00" "#0000ffff"
> DATARANGE 0 32
> end
> style
> COLORRANGE "#0000ffff" "#ff0000ff"
> DATARANGE 32 255
> end
> end
> end
> What I have tried so far has been to comment out this and that but result seems to be always the same.
> -Jukka Rahkonen-
> mapserver-users at lists.osgeo.org
> Thomas RAFFIN
> Chef de Projet Internet
> traffin at sirap.fr
> [image: Sirap] <http://sirap.fr>
> Tel : 04 75 72 84 10
> Fax : 04 75 70 07 98
> Rue Paul Louis Héroult - BP 253
> 26106 Romans cedex
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140929/ac82ef56/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140929/ac82ef56/attachment-0001.png>
