[mapserver-users] digitize plugin problem
eleonora at creativalab.com
Thu Apr 9 01:32:26 PDT 2015
could be a problem of projection ?
include_config.php
$db_table = 'toponimi-cat'; // Table name.
$pkey = 'gid'; // Table's primary key.
$the_geom = 'the_geom'; // Table's geometry field, type POINT.
$srid_geom = 32633; // SRID of the geometry.
$srid_map = 32633; // SRID of the map (clicked screen
point).
$tolerance = 500; // Distance in meteres to pick existing
point for editing.
$hide_fields = array('id'); // Table fields not displayed in the
edit form.
file.map
MAP
EXTENT 350117.586532 4739786.469378 382150.132577 4773295.848327
IMAGECOLOR 255 255 255
UNITS meters
SIZE 600 500
SHAPEPATH "/var/www/data"
SYMBOLSET "../common/symbols/symbols-pmapper.sym"
FONTSET "../common/fonts/msfontset.txt"
RESOLUTION 96
IMAGETYPE png
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
Il 2015-04-09 04:30 eleonora at creativalab.com ha scritto:
> Hello.
> i have some problems with db connection.
> Inside include_config.php i wrote
> $db_host='xxx';
> $db_login='xxx';
> $db_pass='xxx';
> $database = 'xxxx';
> $dsn = "pgsql://$db_login:$db_pass@$db_host/$database";
> In window pop-up the error is DB Error: syntax error
> i try different solutions but even if the reported errors are
> different does not work.
> $dsn = 'pgsql://user:pass@localhost:5432/dbname';
> error : DB Error: syntax error
> $dsn = new
> PDO("pgsql:host=xxxx;dbname=xxxx;user=xxxx;password=xxxx");
> error Unable to include the DB/.php file for '://:PASSWORD@/'
> The connection to the database postgres operating normally as I see
> the layers whose data are taken from the db
> I installed the PHP Pear DB package and PEAR MDB2
> any ideas? after installation I had to restart apache or service
> postgresql?
> thank you
> Eleonora
> mapserver-users at lists.osgeo.org
