[mapserver-users] digitize plugin problem
Thomas RAFFIN
traffin at sirap.fr
Thu Apr 9 01:42:07 PDT 2015
Hi Eleonora,
I think you are not at the right place. You should try pmapper
mailing-list here:
https://lists.sourceforge.net/lists/listinfo/pmapper-users
Thomas
Le 09/04/2015 10:32, eleonora at creativalab.com a écrit :
> could be a problem of projection ?
> include_config.php
> $db_table = 'toponimi-cat'; // Table name.
> $pkey = 'gid'; // Table's primary key.
> $the_geom = 'the_geom'; // Table's geometry field, type POINT.
> $srid_geom = 32633; // SRID of the geometry.
> $srid_map = 32633; // SRID of the map (clicked screen
> point).
> $tolerance = 500; // Distance in meteres to pick
> existing point for editing.
> $hide_fields = array('id'); // Table fields not displayed in the
> edit form.
> file.map
> MAP
> EXTENT 350117.586532 4739786.469378 382150.132577 4773295.848327
> IMAGECOLOR 255 255 255
> UNITS meters
> SIZE 600 500
> SHAPEPATH "/var/www/data"
> SYMBOLSET "../common/symbols/symbols-pmapper.sym"
> FONTSET "../common/fonts/msfontset.txt"
> RESOLUTION 96
> IMAGETYPE png
> PROJECTION
> 'proj=utm'
> 'zone=33'
> 'datum=WGS84'
> 'units=m'
> 'no_defs'
> END
> Il 2015-04-09 04:30 eleonora at creativalab.com ha scritto:
>> Hello.
>> i have some problems with db connection.
>> Inside include_config.php i wrote
>> $db_host='xxx';
>> $db_login='xxx';
>> $db_pass='xxx';
>> $database = 'xxxx';
>> $dsn = "pgsql://$db_login:$db_pass@$db_host/$database";
>> In window pop-up the error is DB Error: syntax error
>> i try different solutions but even if the reported errors are
>> different does not work.
>> $dsn = 'pgsql://user:pass@localhost:5432/dbname';
>> error : DB Error: syntax error
>> $dsn = new
>> PDO("pgsql:host=xxxx;dbname=xxxx;user=xxxx;password=xxxx");
>> error Unable to include the DB/.php file for '://:PASSWORD@/'
>> The connection to the database postgres operating normally as I see
>> the layers whose data are taken from the db
>> I installed the PHP Pear DB package and PEAR MDB2
>> any ideas? after installation I had to restart apache or service
>> postgresql?
>> thank you
>> Eleonora
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
