[mapserver-users] Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
Richard Greenwood
richard.greenwood at gmail.com
Thu Apr 9 17:19:44 PDT 2015
Why are you using a shapefile? Is it a tile index? Have you tried accessing
the ecw file directly? Something like:
LAYER
NAME "ecw"
STATUS default
TYPE raster
DATA "/fullpath/to/0608A1Argb_12_d73.ecw"
END
Ubuntu probably installed gdal, so you may have two copied. To see which
one is first, try
which -a gdalinfo
and verify that the version with ecw support is first.
And if you are still having trouble, please post your layer definition.
rich
On Thu, Apr 9, 2015 at 8:54 AM, Marco Afonso <mafonso333 at gmail.com> wrote:
> Hi all,
> Installed mapserver with apt-get.
> I've installed gdal manually: compiled with ecw support (gdalinfo tell me
> that).
> I'm trying to use a shapefile (which points to ecw files) on mapserver but
> comes the error (the relevant part):
> msDrawMap(): Image handling error. Failed to draw layer named
> 'ortos2012'.
> msDrawRasterLayerLow(): Unable to access file. Corrupt, empty or missing
> file '/fullpath/to/0608A1Argb_12_d73.ecw
> Note also that I'm using the full path to the ecw.
> Any ideas please? Thanks :)
> Regards,
> Marco Afonso
> http://goo.gl/ZDtQjm
> mapserver-users at lists.osgeo.org
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150409/afb59f51/attachment.html>
