[mapserver-users] Multiple MapCache configuration files
geographika
geographika at gmail.com
Mon Aug 24 07:19:01 PDT 2015
Many thanks for the quick reply!
<IfModule mapcache_module>
<Directory "/ms4w/apps/mapcache/">
Order Allow,Deny
Allow from all
</Directory>
MapCacheAlias /mapcache "C:/ms4w/apps/mapcache/mapcache.xml"
MapCacheAlias /mapcache2 "C:/ms4w/apps/mapcache/mapcache2.xml"
</IfModule>
I was getting the following errors in the log at first (even after a
restart):
[Mon Aug 24 14:59:34 2015] [error] [client 127.0.0.1] File does not
exist: C:/ms4w/Apache/htdocs/mapcache2
However after a few restarts of Apache everything started working
correctly.
Regards,
Seth
On 24/08/2015 15:10, Travis Kirstine wrote:
> You can create multiple aliases in apache
> <Directory /path/to/mapcache>
> Order Allow,Deny
> Allow from all
> </Directory>
> MapCacheAlias /mapcache_1 "/path/to/mapcache_1.xml"
> MapCacheAlias /mapcache_2 "/path/to/mapcache_2.xml"
> MapCacheAlias /mapcache_3 "/path/to/mapcache_3.xml"
> </IfModule>
> On Mon, Aug 24, 2015 at 8:51 AM, geographika <geographika at gmail.com
> <mailto:geographika at gmail.com>> wrote:
> Hi,
> As per the configuration guide I have a single xml configuration
> file for all MapCache layers. This is set in httpd.conf (I'm using
> ms4w, and running on a Windows server):
> Order Allow,Deny
> Allow from all
> </Directory>
> </IfModule>
> However I'm using MapCache on a development server and hosting
> several different applications. I create the xml file dynamically
> for each application, however with this approach I either have to
> change the above path and restart Apache, or merge all the xml
> files together to a single file.
> Is there anyway to change which xml file is used using a
> querystring, or is there any other suggested approach to handling
> multiple mapcache.xml files?
> Regards,
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> FBS Logo
> *Travis Kirstine*, Web Development Supervisor
> *t *905‑477‑3600/ x /301 | *m *905‑534‑4798 |
> tkirstine at firstbasesolution.com <mailto:tkirstine at firstbasesolution.com>
> *First Base Solutions Inc.*
> 140 Renfrew Drive, Suite 100 | Markham | Ontario | L3R 6B3
> *t* 905‑477‑3600 | *f* 905‑477‑0892 | www.firstbasesolutions.com
> <http://www.firstbasesolutions.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150824/ce0bf81d/attachment.html>
