[mapserver-users] [Mac OS X] Impossible to load MapScript module with PHP
Léonard DUMONT
dumont.leonard at gmail.com
Fri Dec 11 04:03:08 PST 2015
Ok, thanks for your answer. I thought there could have been another
solution, but I'll try to install PHP with homebrew.
Cordialement,
Léonard Dumont
2015-12-11 10:33 GMT+01:00 Ben Madin <ben at ausvet.com.au>:
> Um, you are correct, the extension has not been compiled to work with the
> same version of php as you are trying to use.
> I can only suggest that you get your php from the same source as your
> mapscript... (I guess homebrew, but my success there has been limited and
> conflicted) or compile php yourself, them mapserver with the php-mapscript
> option set.
> You may be up for some pain...! You could also try kyngchaos.com, but I'm
> not sure if he is still providing a php suitable for what you want.
> On 10 December 2015 at 17:28, Leonard <dumont.leonard at gmail.com> wrote:
>> Hi everyone !
>> I am a new user trying to use mapserver, and I have some problems... One
>> of
>> them is that I cannot load the php_mapscript extension. I have PHP 5.6.11
>> installed with php-osx.liip.ch <http://php-osx.liip.ch> and mapscript
>> 6.4
>> installed with Homebrew, and there seems to be a conflict, since when I
>> run
>> php I get this warning :
>> Warning: PHP Startup: MapScript: Unable to initialize module
>> Module compiled with module API=20100525
>> PHP compiled with module API=20131226
>> These options need to match
>> I added this line to my php.ini file :
>> extension="/usr/local/opt/mapserver-64/mapscript/php/php_mapscript.so"
>> Thanks for your help !
>> Léonard Dumont.
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Mac-OS-X-Impossible-to-load-MapScript-module-with-PHP-tp5240669.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Ben Madin
> BVMS PhD, MANZCVS
> t : +61 8 6102 5535
> m : +61 448 887 220
> e : ben at ausvet.com.au
> AusVet Animal Health Services
> Western Australia
> www.ausvet.com.au
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151211/dead577e/attachment.html>
