[mapserver-users] [Mac OS X] Impossible to load MapScript module with PHP
Léonard DUMONT
dumont.leonard at gmail.com
Fri Dec 11 04:38:33 PST 2015
Finally it was not so hard, but the problem is still the same... I have PHP
5.6.16 and Mapscript 6.4.1 both installed with Homebrew, and I still have
the same error :
Warning: PHP Startup: MapScript: Unable to initialize module
Module compiled with module API=20100525
PHP compiled with module API=20131226
These options need to match
in Unknown on line 0
Any ideas ?
Best regards,
Léonard Dumont
2015-12-11 13:03 GMT+01:00 Léonard DUMONT <dumont.leonard at gmail.com>:
> Ok, thanks for your answer. I thought there could have been another
> solution, but I'll try to install PHP with homebrew.
> Cordialement,
> Léonard Dumont
> 2015-12-11 10:33 GMT+01:00 Ben Madin <ben at ausvet.com.au>:
>> Um, you are correct, the extension has not been compiled to work with the
>> same version of php as you are trying to use.
>> I can only suggest that you get your php from the same source as your
>> mapscript... (I guess homebrew, but my success there has been limited and
>> conflicted) or compile php yourself, them mapserver with the php-mapscript
>> option set.
>> You may be up for some pain...! You could also try kyngchaos.com, but
>> I'm not sure if he is still providing a php suitable for what you want.
>> On 10 December 2015 at 17:28, Leonard <dumont.leonard at gmail.com> wrote:
>>> Hi everyone !
>>> I am a new user trying to use mapserver, and I have some problems... One
>>> of
>>> them is that I cannot load the php_mapscript extension. I have PHP 5.6.11
>>> installed with php-osx.liip.ch <http://php-osx.liip.ch> and
>>> mapscript 6.4
>>> installed with Homebrew, and there seems to be a conflict, since when I
>>> run
>>> php I get this warning :
>>> I added this line to my php.ini file :
>>> extension="/usr/local/opt/mapserver-64/mapscript/php/php_mapscript.so"
>>> Thanks for your help !
>>> Léonard Dumont.
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/Mac-OS-X-Impossible-to-load-MapScript-module-with-PHP-tp5240669.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Ben Madin
>> BVMS PhD, MANZCVS
>> t : +61 8 6102 5535
>> m : +61 448 887 220
>> e : ben at ausvet.com.au
>> AusVet Animal Health Services
>> Western Australia
>> www.ausvet.com.au
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151211/0092d2b0/attachment.html>
