[mapserver-users] [EXTERNAL] WMS SRS as variable
Schylberg Lars
lars.schylberg at saabgroup.com
Mon Feb 9 01:26:57 PST 2015
Mike,
Thanks for your reply, but it is when I call the wms services as a client I get the errors already in the validation. I would like to do something like this:
But I guess I am doing something that is not meant to be this way.
MAP
NAME MAP_MAIN
SIZE 1000 1000
CONFIG "PROJ_LIB" './'
UNITS dd
EXTENT 9.624750 52.33333 30.333333 66.500000
PROJECTION
'init=epsg:4326'
END
IMAGETYPE png
FONTSET './fonts/fontset.lst'
SYMBOLSET "./symbols/symbols.sym"
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
SHAPEPATH ../data/shape
WEB
IMAGEPATH '/tmp/'
IMAGEURL '/tmp/'
METADATA
"ows_enable_request" "*"
'wms_title' 'MAP_MAIN'
'wms_srs' 'EPSG:32633 EPSG:3006 EPSG:900913 EPSG:4326'
"labelcache_map_edge_buffer" "-10"
END
END
VALIDATION
"srs" "^[0-9]{4,5)$"
END
############### Layer 0 as WMS request
LAYER
NAME "WMS-layer-0"
OFFSITE 200 0 0
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION "http://localhost/cgi-bin/mapserv?map=/var/www/html/map0.map"
METADATA
"wms_srs" 'EPSG:''%srs%'
"wms_name" "map0"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_exceptions_format" "application/vnd.ogc.se_inimage"
END
END #layer
############### Layer 1 as WMS request
LAYER
NAME "WMS-layer-1"
OFFSITE 200 0 0
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION "http://localhost/cgi-bin/mapserv?map=/var/www/html/map1.map"
METADATA
"wms_name" "map1"
END
END #layer
END # Map
From: Smith, Michael ERDC-RDE-CRREL-NH [mailto:Michael.Smith at erdc.dren.mil]
Sent: den 6 februari 2015 16:31
To: Schylberg Lars; mapserver-users at lists.osgeo.org
Subject: Re: [EXTERNAL] [mapserver-users] WMS SRS as variable
Lars,
A WMS map can support multiple SRS's. Just list all the ones you want in the METADATA block. Look at http://mapserver.org/ogc/wms_server.html and specifically the Map PROJECTION and wms_srs metadata. From the example, you can see that 2 SRS's are supported.
METADATA
"wms_title" "WMS Demo Server"
"wms_onlineresource" "http://my.host.com/cgi-bin/mapserv?map=wms.map&"
"wms_srs" "EPSG:4269 EPSG:4326"
END
Just keep adding to the list to support more projections.
Mike
From: Schylberg Lars <lars.schylberg at saabgroup.com<mailto:lars.schylberg at saabgroup.com>>
Date: Friday, February 6, 2015 at 10:05 AM
To: "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [EXTERNAL] [mapserver-users] WMS SRS as variable
Resent-From: Michael Smith <michael.smith at usace.army.mil<mailto:michael.smith at usace.army.mil>>
Hello,
I wonder if there is a way to set SRS as a variable in a map file.
I have one map file that uses several other WMS clients that also are mapfiles.
I would like to use the SRS as variable to make the WMS service more flexible.
I have tried to do VALIDATION on SRS variable, but that only gives errors.
Thanks /Lars S.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150209/66a7bd7e/attachment-0001.html>
