[mapserver-users] MapServer Environment Variables and IIS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Feb 9 12:48:29 PST 2015
On 2015-02-09 1:03 PM, geographika wrote:
> Thanks Jeff.
> The environment variable is definitely set in system variables, and I've
> rebooted a few times now. It also happens on both a w08r2 server and a
> Windows 7 machine.
> I can see it in
> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session
> Manager\Environment
> I'm using x64 MapServer, but the environment variables appear in my x64
> Python script.
> I had this working a couple of years ago, and tried to see if anything
> has changed in the MS source since but no luck.
> I think I should also be able to set it in the web.config using the
> following, but also no luck:
> <fastCgi>
> <application fullPath="C:\Mapserver\bin\mapserv.exe">
> <environmentVariables>
> <environmentVariable name="CURL_CA_BUNDLE"
> value="C:\Mapserver\bin\curl\curl-ca-bundle.crt" />
> </environmentVariables>
> </application>
> </fastCgi>
> Regards,
> Seth
I think I may been in your exact shoes once, and it was a problem with
the Curl library in the MapServer build (I believe Curl is used for this
certification/communication, along with the OpenSSL, but you could
clarify this with other developers). I would also test with MS4W to see
if you get the same problem.
I think you said it used to work with an older MapServer version; I
would therefore test on that same server with that same older MapServer
version/package again too.
Ha, this is how I debug (yes gives you grey hairs ha!).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
