[mapserver-users] layer handling in Mapserver WMS clients
Schylberg Lars
lars.schylberg at saabgroup.com
Tue Feb 10 01:24:14 PST 2015
I have a follow up question on my question yesterday. I would like to have the layers in the main called mapfile to be set layers in the client WMS calls.
The WMS client documentation says, http://mapserver.org/ogc/wms_client.html :
"wms_name" metadata - comma-separated list of layers to be fetched from the remote WMS server. This value is used to set the LAYERS and QUERY_LAYERS WMS URL parameters
When I call the MAP_MAIN I would like to call it like this:
http://localhost/cgi-bin/mapserv?map=/var/www/html/map2/MAP_MAIN.map
&SERVICE=WMS&REQUEST=Getmap&VERSION=1.1.1
&LAYERS=base,marks,text&srs=EPSG:4326&BBOX=9.624750,52.33333,30.333333,66.500000
&FORMAT=application/openlayers&WIDTH=2000&HEIGHT=1100
or &LAYERS=base,text or &LAYERS=base
Is the mechanism similar to the srs handling?
How do I expose the layers in the wms clients map files? Right now I use GROUP to define the layers and that works when I call it directly. Or is it so that I have to expose the layers with
WMS_LAYER_GROUP in the wms-server mapfiles that are called as clients? I haven't been successful with that! I have several clients with the same layer structure and one with just default.
/Lars
MAP
NAME MAP_MAIN
SIZE 1000 1000
CONFIG "PROJ_LIB" './'
UNITS dd
EXTENT 9.624750 52.33333 30.333333 66.500000
PROJECTION
'init=epsg:4326'
END
IMAGETYPE png
FONTSET './fonts/fontset.lst'
SYMBOLSET "./symbols/symbols.sym"
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
SHAPEPATH ../data/shape
WEB
IMAGEPATH '/tmp/'
IMAGEURL '/tmp/'
METADATA
"ows_enable_request" "*"
'wms_title' 'MAP_MAIN'
'wms_srs' 'EPSG:32633 EPSG:3006 EPSG:3857 EPSG:4326'
"labelcache_map_edge_buffer" "-10"
END
END
############### Layer 0 as WMS request
LAYER
NAME "WMS-layer-0"
OFFSITE 200 0 0
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION "http://localhost/cgi-bin/mapserv?map=/var/www/html/map0.map"
METADATA
"wms_name" "default"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_exceptions_format" "application/vnd.ogc.se_inimage"
END
END #layer
############### Layer 1 as WMS request
LAYER
NAME "WMS-layer-1"
OFFSITE 200 0 0
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION "http://localhost/cgi-bin/mapserv?map=/var/www/html/map1.map"
METADATA
"wms_name" " base,marks,text" #???????????
END
END #layer
END # Map
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150210/ca88e0d2/attachment.html>
