[mapserver-users] MapServer Environment Variables and IIS
thomas bonfort
thomas.bonfort at gmail.com
Tue Feb 10 05:22:28 PST 2015
Mod fcgid on apache has special directives to set environment variables,
c.f. FcgidInitialEnv . on iis you hopefully have the same...
On Feb 10, 2015 8:18 AM, "geographika" <geographika at gmail.com> wrote:
> Some further details after debugging. I modified mmaphttp.c and recompiled
> MapServer just to confirm the missing environment variables.
> // pszCurlCABundle = "C:\\MapServer\\bin\\curl\\curl-ca-bundle.crt"; //
> works when hardcoded
> pszCurlCABundle = getenv("Path");
> msDebug("Test CURL_CA_BUNDLE=%s\n", pszCurlCABundle);
> test1 = getenv("Path");
> msDebug("Path=%s\n", test1);
> Then run using mapserv the env variables are correct. When run in IIS
> using FastCGI both appear as null in the log file.
> [Tue Feb 10 13:54:13 2015].868000 Test CURL_CA_BUNDLE=(null)
> [Tue Feb 10 13:54:13 2015].868000 Path=(null)
> getenv is part of the standard C library http://www.codingunit.com/c-
> reference-stdlib-h-function-getenv
> So I guess this must be an IIS/FastCGI issue rather than MapServer?
> Seth
> On 09/02/2015 21:48, Jeff McKenna wrote:
>> On 2015-02-09 1:03 PM, geographika wrote:
>>> Thanks Jeff.
>>> The environment variable is definitely set in system variables, and I've
>>> rebooted a few times now. It also happens on both a w08r2 server and a
>>> Windows 7 machine.
>>> I can see it in
>>> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session
>>> Manager\Environment
>>> I'm using x64 MapServer, but the environment variables appear in my x64
>>> Python script.
>>> I had this working a couple of years ago, and tried to see if anything
>>> has changed in the MS source since but no luck.
>>> I think I should also be able to set it in the web.config using the
>>> following, but also no luck:
>>> <fastCgi>
>>> <application fullPath="C:\Mapserver\bin\mapserv.exe">
>>> <environmentVariables>
>>> <environmentVariable name="CURL_CA_BUNDLE"
>>> value="C:\Mapserver\bin\curl\curl-ca-bundle.crt" />
>>> </environmentVariables>
>>> </application>
>>> </fastCgi>
>>> Regards,
>>> Seth
>> I think I may been in your exact shoes once, and it was a problem with
>> the Curl library in the MapServer build (I believe Curl is used for this
>> certification/communication, along with the OpenSSL, but you could clarify
>> this with other developers). I would also test with MS4W to see if you get
>> the same problem.
>> I think you said it used to work with an older MapServer version; I would
>> therefore test on that same server with that same older MapServer
>> version/package again too.
>> Ha, this is how I debug (yes gives you grey hairs ha!).
>> -jeff
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150210/f4e04332/attachment.html>
