[mapserver-users] multiple mapserv versions side by side
thomas bonfort
thomas.bonfort at gmail.com
Wed Feb 18 02:05:56 PST 2015
You /should/, at least on linux, be able to install to any non
standard location without having to compile a static version by using
"cmake .. -DCMAKE_INSTALL_PATH=/opt/ms70" and then copying/symlinking
/opt/ms70/bin/mapserv to your standard cgi directory. The compiled
php_mapscript.so should also pick up the non standard location,
although you'll have to manually configure php to use the new
php_mapscript.so library. You'll definitely run into issues if you
have php load multiple versions of php_mapscript.so.
thomas
On 18 February 2015 at 04:14, Richard Greenwood
<richard.greenwood at gmail.com> wrote:
> Thanks Daniel. I'd like to also have php mapscript but with static linking
> i'm getting error below. Any suggestions for that?
> Linking CXX shared module php_mapscript.so
> /usr/bin/ld: ../../libmapserver_static.a(cgiutil.c.o): relocation
> R_X86_64_32 against `.rodata' can not be used when making a shared object;
> recompile with -fPIC
> ../../libmapserver_static.a: error adding symbols: Bad value
> collect2: error: ld returned 1 exit status
> make[2]: *** [mapscript/php/php_mapscript.so] Error 1
> On Tue, Feb 17, 2015 at 7:48 PM, Daniel Morissette
> <dmorissette at mapgears.com> wrote:
>> On 2015-02-17 9:18 PM, Richard Greenwood wrote:
>>> I'd like to play with the mapserv 7 beta on the same Ubuntu machine that
>>> I have mapserv 6.4 installed on. But both versions are using
>>> libmapserver.so so depending on what I have in my ldconfig path it's
>>> finding the 6.4 version lib or the 7beta ib. Is there an easier way to
>>> have both versions without changing ldconfig each time I switch between
>>> the two versions? Sorry, I know this is probably a pretty basic Linux
>>> question.
>> Hi Rich,
>> Use
>> cmake ... -DLINK_STATIC_LIBMAPSERVER=1 ...
>> and libmapserver.a will be statically linked into your mapserv executable,
>> and then you can simply copy the executable to your cgi-bin
>> cp ./mapserv /usr/lib/cgi-bin/mapserv70
>> Daniel Morissette
>> T: +1 418-696-5056 #201
>> http://www.mapgears.com/
>> Provider of Professional MapServer Support since 2000
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
