[mapserver-users] Return pixel values from raster layers served by mapserver
Bill Hudspeth
bhudspeth at edac.unm.edu
Tue Jan 6 06:58:31 PST 2015
Hello,
I previously wrote about this issue, but have not found a solution yet. I am running Mapserver 6.4.1, and am using Postgres/Postgis to display a time series of geotiff images. I would like to know the best way for a user to submit a given x,y coordinate pair and return the pixel value for a given image. Is this possible using only the mapserver api? or must I absolutely use mapscript?
Currently, I use a PostgreSQL/PostGIS time-enabled table to store the information about the location of the geotiffs and the timestamp associated with them:
pm25_monthly=# \d pm25_monthly_global
Table
"public.pm25_monthly_global"
Column | Type |
Modifiers
oid | integer | default nextval('pm25_monthly_seq'::regclass)
rundate | timestamp with time zone |
datetime | timestamp with time zone |
location | text |
timezone | timestamp without time zone |
the_geom | geometry(MultiPolygon,4326) |
Indexes:
"pm25_monthly_global_oid_key"
UNIQUE CONSTRAINT, btree (oid)
The 'location' field simply gives the full path to the relevant geotiff on the file system. And, I define the index in the mapfile:
#**********LAYER - TILE INDEX FOR PM2.5 RASTERS
(Time sensitive)****
LAYER
STATUS ON
NAME "pm25_time_index"
TYPE POLYGON
DATA "the_geom from pm25_monthly_global using unique oid using SRID=4326"
METADATA
"ows_title" "PM25 TIME INDEX"
"ows_srs" "EPSG:4326"
"ows_extent" "-180 -90 180 90" #[minx][miny][maxx][maxy]
"wms_timeformat" "YYYY-MM-DDTHH:MM:SS"
"wms_timeextent" "2011-01-01T00:00:00/2012-12-01T00:00:00"
"wms_timeitem" "timezone"
"wms_timedefault" "2011-01-01T00:00:00"
wcs_resolution '0:10 0:10'
END
#CONNECTION "user=wilbur dbname=pm25_monthly host=localhost password=iiiiiiiiii"
#CONNECTIONTYPE postgis
CONNECTIONTYPE POSTGIS
CONNECTION "host=127.0.0.1 dbname=pm25_monthly user=wilbur password=EUR2_live port=5432"
DATA "the_geom from pm25_monthly_global using unique oid using srid=4326"
END
#*******LAYER - MONTHLY PM2.5 (Time Sensitive)*********************************
LAYER
NAME 'pm25_monthly'
TYPE RASTER
STATUS ON
DEBUG OFF
DUMP TRUE
#TRANSPARENCY 50
#FILTER ""
METADATA
"ows_keywordlist" 'PM2.5 (ug/m3), Global' #wms_keywordlist (Keywordlist)
"ows_description" "Global monthly mean PM 2.5 (ug/m3)concentration"
"ows_name" "Global monthly mean PM2.5 - Concentration Values (ug/m3)"
"ows_label" "Global PM 2.5 (ug/m3)"
"ows_srs" "EPSG:4326 EPSG:900913"
"ows_formats" "GEOTIFF"
"ows_nativeformat" "8-bit GeoTIF"
"ows_timeitem" "timezone"
"wms_onlineresource" "http://localhost/cgi-bin/mapserv?map=/var/www/pm25_mapserver/public_html/pm25_ogc_services.map"
"wms_abstract" 'Global monthly mean PM 2.5 (ug/m3)concentration' #wms_abstract(Abstract)
"wms_opaque" '0' #wms_opaque(layer)
"wms_title" "Global monthly mean PM 2.5 (ug/m3)concentration"
"ows_timeformat" "YYYY-MM-DDTHH:MM:SSZ"
"ows_timeextent" "2011-01-01T00:00:00Z/2012-12-01T00:00:00Z"
"ows_timedefault" "2011-01-01T00:00:00Z"
"wms_enable_request" "*"
"wcs_resolution" "0:10 0:10"
"wcs_bandcount" "1"
"wcs_size" "3600 1800"
layer_name pm25_monthly
END #METADATA
PROJECTION
"init=epsg:4326" #WGS84 Decimal Degrees
END #PROJECTION
TILEITEM "location"
TILEINDEX "pm25_time_index"
END #LAYER
Thanks
