[mapserver-users] Return pixel values from raster layers served by mapserver
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Jan 6 08:37:51 PST 2015
If you want to use one x/y to query multiple rasters, that should be doable in straight MapServer although I guess it depends on how things are organized. I don't know how things work from a query perspective if you use your tile index as just a spatial index and not a temporal index. I'd get the one layer version working then expand it - make sure the PG tileindex works as expected with a query.
-----Original Message-----
From: William Hudspeth [mailto:bhudspeth at edac.unm.edu]
Sent: Tuesday, January 06, 2015 10:02 AM
To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Return pixel values from raster layers served by mapserver
I have not yet tried a TEMPLATE....ideally, I am looking for a method to script a series of calls to mapserver to return a list of pixel values for a time series of rasters for a given geographic coordinate. In this case, imagine a time series of air pollution rasters where I want to collect a sequence of values for a given city or location. I want to be able to use these data points to build a time series graph....Any ideas would be appreciated...
Thanks!
On 01/06/2015 08:44 AM, Lime, Steve D (MNIT) wrote:
> Ok, so this just a PostGIS-based tiled layer to access GeoTIFF's. You should just be able to do a normal MapServer query.
> e.g.
> http://your.server/cgi-bin/mapserv?map=your.map&mapxy=x+y&qlayer=pm25_
> monthly&mode=query
> You'd need to set a TEMPLATE for the pm25_monthly layer. Have you tried that? WMS should work then too but it's simpler to debug using a basic MapServer query.
> Steve
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bill
> Hudspeth
> Sent: Tuesday, January 06, 2015 8:59 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Return pixel values from raster layers
> served by mapserver
> Hello,
> I previously wrote about this issue, but have not found a solution yet. I am running Mapserver 6.4.1, and am using Postgres/Postgis to display a time series of geotiff images. I would like to know the best way for a user to submit a given x,y coordinate pair and return the pixel value for a given image. Is this possible using only the mapserver api? or must I absolutely use mapscript?
> Currently, I use a PostgreSQL/PostGIS time-enabled table to store the information about the location of the geotiffs and the timestamp associated with them:
> pm25_monthly=# \d pm25_monthly_global
> Table
> "public.pm25_monthly_global"
> Column | Type |
> Modifiers
> oid | integer | default nextval('pm25_monthly_seq'::regclass)
> rundate | timestamp with time zone |
> datetime | timestamp with time zone |
> location | text |
> timezone | timestamp without time zone |
> the_geom | geometry(MultiPolygon,4326) |
> Indexes:
> "pm25_monthly_global_oid_key"
> UNIQUE CONSTRAINT, btree (oid)
> The 'location' field simply gives the full path to the relevant geotiff on the file system. And, I define the index in the mapfile:
> #**********LAYER - TILE INDEX FOR PM2.5 RASTERS (Time sensitive)**** LAYER
> STATUS ON
> NAME "pm25_time_index"
> TYPE POLYGON
> DATA "the_geom from pm25_monthly_global using unique oid using SRID=4326"
> METADATA
> "ows_title" "PM25 TIME INDEX"
> "ows_srs" "EPSG:4326"
> "ows_extent" "-180 -90 180 90" #[minx][miny][maxx][maxy]
> "wms_timeformat" "YYYY-MM-DDTHH:MM:SS"
> "wms_timeextent" "2011-01-01T00:00:00/2012-12-01T00:00:00"
> "wms_timeitem" "timezone"
> "wms_timedefault" "2011-01-01T00:00:00"
> wcs_resolution '0:10 0:10'
> END
> #CONNECTION "user=wilbur dbname=pm25_monthly host=localhost password=iiiiiiiiii"
> #CONNECTIONTYPE postgis
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=127.0.0.1 dbname=pm25_monthly user=wilbur password=EUR2_live port=5432"
> DATA "the_geom from pm25_monthly_global using unique oid using srid=4326"
> END
> #*******LAYER - MONTHLY PM2.5 (Time
> Sensitive)*********************************
> LAYER
> NAME 'pm25_monthly'
> TYPE RASTER
> STATUS ON
> DEBUG OFF
> DUMP TRUE
> #TRANSPARENCY 50
> #FILTER ""
> METADATA
> "ows_keywordlist" 'PM2.5 (ug/m3), Global' #wms_keywordlist (Keywordlist)
> "ows_description" "Global monthly mean PM 2.5 (ug/m3)concentration"
> "ows_name" "Global monthly mean PM2.5 - Concentration Values (ug/m3)"
> "ows_label" "Global PM 2.5 (ug/m3)"
> "ows_srs" "EPSG:4326 EPSG:900913"
> "ows_formats" "GEOTIFF"
> "ows_nativeformat" "8-bit GeoTIF"
> "ows_timeitem" "timezone"
> "wms_onlineresource" "http://localhost/cgi-bin/mapserv?map=/var/www/pm25_mapserver/public_html/pm25_ogc_services.map"
> "wms_abstract" 'Global monthly mean PM 2.5 (ug/m3)concentration' #wms_abstract(Abstract)
> "wms_opaque" '0' #wms_opaque(layer)
> "wms_title" "Global monthly mean PM 2.5 (ug/m3)concentration"
> "ows_timeformat" "YYYY-MM-DDTHH:MM:SSZ"
> "ows_timeextent" "2011-01-01T00:00:00Z/2012-12-01T00:00:00Z"
> "ows_timedefault" "2011-01-01T00:00:00Z"
> "wms_enable_request" "*"
> "wcs_resolution" "0:10 0:10"
> "wcs_bandcount" "1"
> "wcs_size" "3600 1800"
> layer_name pm25_monthly
> END #METADATA
> PROJECTION
> "init=epsg:4326" #WGS84 Decimal Degrees
> END #PROJECTION
> TILEITEM "location"
> TILEINDEX "pm25_time_index"
> END #LAYER
> Thanks
