[mapserver-users] Return pixel values from raster layers served by mapserver
William Hudspeth
bhudspeth at edac.unm.edu
Tue Jan 6 09:09:44 PST 2015
I guess I am a little unclear as to how to proceed. The PG temporal
index already works for WMS calls. I can pass a time stamp in the URL
request, and I get the correct image. Do I still need a template for
returning the x/y query? Or is there another way to return the values
via a script that sequentially runs through a list of times?
On 01/06/2015 09:37 AM, Lime, Steve D (MNIT) wrote:
> If you want to use one x/y to query multiple rasters, that should be doable in straight MapServer although I guess it depends on how things are organized. I don't know how things work from a query perspective if you use your tile index as just a spatial index and not a temporal index. I'd get the one layer version working then expand it - make sure the PG tileindex works as expected with a query.
> -----Original Message-----
> From: William Hudspeth [mailto:bhudspeth at edac.unm.edu]
> Sent: Tuesday, January 06, 2015 10:02 AM
> To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Return pixel values from raster layers served by mapserver
> I have not yet tried a TEMPLATE....ideally, I am looking for a method to script a series of calls to mapserver to return a list of pixel values for a time series of rasters for a given geographic coordinate. In this case, imagine a time series of air pollution rasters where I want to collect a sequence of values for a given city or location. I want to be able to use these data points to build a time series graph....Any ideas would be appreciated...
> Thanks!
> On 01/06/2015 08:44 AM, Lime, Steve D (MNIT) wrote:
>> Ok, so this just a PostGIS-based tiled layer to access GeoTIFF's. You should just be able to do a normal MapServer query.
>> e.g.
>> http://your.server/cgi-bin/mapserv?map=your.map&mapxy=x+y&qlayer=pm25_
>> monthly&mode=query
>> You'd need to set a TEMPLATE for the pm25_monthly layer. Have you tried that? WMS should work then too but it's simpler to debug using a basic MapServer query.
>> Steve
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bill
>> Hudspeth
>> Sent: Tuesday, January 06, 2015 8:59 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] Return pixel values from raster layers
>> served by mapserver
>> Hello,
>> I previously wrote about this issue, but have not found a solution yet. I am running Mapserver 6.4.1, and am using Postgres/Postgis to display a time series of geotiff images. I would like to know the best way for a user to submit a given x,y coordinate pair and return the pixel value for a given image. Is this possible using only the mapserver api? or must I absolutely use mapscript?
>> Currently, I use a PostgreSQL/PostGIS time-enabled table to store the information about the location of the geotiffs and the timestamp associated with them:
>> pm25_monthly=# \d pm25_monthly_global
>> Table
>> "public.pm25_monthly_global"
>> Column | Type |
>> Modifiers
>> oid | integer | default nextval('pm25_monthly_seq'::regclass)
>> rundate | timestamp with time zone |
>> datetime | timestamp with time zone |
>> location | text |
>> timezone | timestamp without time zone |
>> the_geom | geometry(MultiPolygon,4326) |
>> Indexes:
>> "pm25_monthly_global_oid_key"
>> UNIQUE CONSTRAINT, btree (oid)
>> The 'location' field simply gives the full path to the relevant geotiff on the file system. And, I define the index in the mapfile:
>> #**********LAYER - TILE INDEX FOR PM2.5 RASTERS (Time sensitive)**** LAYER
>> STATUS ON
>> NAME "pm25_time_index"
>> TYPE POLYGON
>> DATA "the_geom from pm25_monthly_global using unique oid using SRID=4326"
>> METADATA
>> "ows_title" "PM25 TIME INDEX"
>> "ows_srs" "EPSG:4326"
>> "ows_extent" "-180 -90 180 90" #[minx][miny][maxx][maxy]
>> "wms_timeformat" "YYYY-MM-DDTHH:MM:SS"
>> "wms_timeextent" "2011-01-01T00:00:00/2012-12-01T00:00:00"
>> "wms_timeitem" "timezone"
>> "wms_timedefault" "2011-01-01T00:00:00"
>> wcs_resolution '0:10 0:10'
>> END
>> #CONNECTION "user=wilbur dbname=pm25_monthly host=localhost password=iiiiiiiiii"
>> #CONNECTIONTYPE postgis
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "host=127.0.0.1 dbname=pm25_monthly user=wilbur password=EUR2_live port=5432"
>> DATA "the_geom from pm25_monthly_global using unique oid using srid=4326"
>> END
>> #*******LAYER - MONTHLY PM2.5 (Time
>> Sensitive)*********************************
>> LAYER
>> NAME 'pm25_monthly'
>> TYPE RASTER
>> STATUS ON
>> DEBUG OFF
>> DUMP TRUE
>> #TRANSPARENCY 50
>> #FILTER ""
>> METADATA
>> "ows_keywordlist" 'PM2.5 (ug/m3), Global' #wms_keywordlist (Keywordlist)
>> "ows_description" "Global monthly mean PM 2.5 (ug/m3)concentration"
>> "ows_name" "Global monthly mean PM2.5 - Concentration Values (ug/m3)"
>> "ows_label" "Global PM 2.5 (ug/m3)"
>> "ows_srs" "EPSG:4326 EPSG:900913"
>> "ows_formats" "GEOTIFF"
>> "ows_nativeformat" "8-bit GeoTIF"
>> "ows_timeitem" "timezone"
>> "wms_onlineresource" "http://localhost/cgi-bin/mapserv?map=/var/www/pm25_mapserver/public_html/pm25_ogc_services.map"
>> "wms_abstract" 'Global monthly mean PM 2.5 (ug/m3)concentration' #wms_abstract(Abstract)
>> "wms_opaque" '0' #wms_opaque(layer)
>> "wms_title" "Global monthly mean PM 2.5 (ug/m3)concentration"
>> "ows_timeformat" "YYYY-MM-DDTHH:MM:SSZ"
>> "ows_timeextent" "2011-01-01T00:00:00Z/2012-12-01T00:00:00Z"
>> "ows_timedefault" "2011-01-01T00:00:00Z"
>> "wms_enable_request" "*"
>> "wcs_resolution" "0:10 0:10"
>> "wcs_bandcount" "1"
>> "wcs_size" "3600 1800"
>> layer_name pm25_monthly
>> END #METADATA
>> PROJECTION
>> "init=epsg:4326" #WGS84 Decimal Degrees
>> END #PROJECTION
>> TILEITEM "location"
>> TILEINDEX "pm25_time_index"
>> END #LAYER
>> Thanks
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
