[mapserver-users] Return pixel values from raster layers served by mapserver
Andrea Peri
aperi2007 at gmail.com
Tue Jan 6 11:00:32 PST 2015
I guess you could get it as a normally GetFeatureInfo request.
We use it usually to retrive the quote from a raster DEM.
You should set a template and do a request GetFeatureInfo with output
format = text/html.
In the template you should retrieve :
the RGB values separatelly for R,G and B or for a raster DEM the quote value.
AFAIK The only relevant difference difference is the input format.
Infct we use the spatialite using the OGR.
But I guess it should work also with postgis provider.
regards,
A.
2015-01-06 15:58 GMT+01:00 Bill Hudspeth <bhudspeth at edac.unm.edu>:
> Hello,
> I previously wrote about this issue, but have not found a solution yet. I am running Mapserver 6.4.1, and am using Postgres/Postgis to display a time series of geotiff images. I would like to know the best way for a user to submit a given x,y coordinate pair and return the pixel value for a given image. Is this possible using only the mapserver api? or must I absolutely use mapscript?
> Currently, I use a PostgreSQL/PostGIS time-enabled table to store the information about the location of the geotiffs and the timestamp associated with them:
> pm25_monthly=# \d pm25_monthly_global
> Table
> "public.pm25_monthly_global"
> Column | Type |
> Modifiers
> oid | integer | default nextval('pm25_monthly_seq'::regclass)
> rundate | timestamp with time zone |
> datetime | timestamp with time zone |
> location | text |
> timezone | timestamp without time zone |
> the_geom | geometry(MultiPolygon,4326) |
> Indexes:
> "pm25_monthly_global_oid_key"
> UNIQUE CONSTRAINT, btree (oid)
> The 'location' field simply gives the full path to the relevant geotiff on the file system. And, I define the index in the mapfile:
> #**********LAYER - TILE INDEX FOR PM2.5 RASTERS
> (Time sensitive)****
> LAYER
> STATUS ON
> NAME "pm25_time_index"
> TYPE POLYGON
> DATA "the_geom from pm25_monthly_global using unique oid using SRID=4326"
> METADATA
> "ows_title" "PM25 TIME INDEX"
> "ows_srs" "EPSG:4326"
> "ows_extent" "-180 -90 180 90" #[minx][miny][maxx][maxy]
> "wms_timeformat" "YYYY-MM-DDTHH:MM:SS"
> "wms_timeextent" "2011-01-01T00:00:00/2012-12-01T00:00:00"
> "wms_timeitem" "timezone"
> "wms_timedefault" "2011-01-01T00:00:00"
> wcs_resolution '0:10 0:10'
> END
> #CONNECTION "user=wilbur dbname=pm25_monthly host=localhost password=iiiiiiiiii"
> #CONNECTIONTYPE postgis
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=127.0.0.1 dbname=pm25_monthly user=wilbur password=EUR2_live port=5432"
> DATA "the_geom from pm25_monthly_global using unique oid using srid=4326"
> END
> #*******LAYER - MONTHLY PM2.5 (Time Sensitive)*********************************
> LAYER
> NAME 'pm25_monthly'
> TYPE RASTER
> STATUS ON
> DEBUG OFF
> DUMP TRUE
> #TRANSPARENCY 50
> #FILTER ""
> METADATA
> "ows_keywordlist" 'PM2.5 (ug/m3), Global' #wms_keywordlist (Keywordlist)
> "ows_description" "Global monthly mean PM 2.5 (ug/m3)concentration"
> "ows_name" "Global monthly mean PM2.5 - Concentration Values (ug/m3)"
> "ows_label" "Global PM 2.5 (ug/m3)"
> "ows_srs" "EPSG:4326 EPSG:900913"
> "ows_formats" "GEOTIFF"
> "ows_nativeformat" "8-bit GeoTIF"
> "ows_timeitem" "timezone"
> "wms_onlineresource" "http://localhost/cgi-bin/mapserv?map=/var/www/pm25_mapserver/public_html/pm25_ogc_services.map"
> "wms_abstract" 'Global monthly mean PM 2.5 (ug/m3)concentration' #wms_abstract(Abstract)
> "wms_opaque" '0' #wms_opaque(layer)
> "wms_title" "Global monthly mean PM 2.5 (ug/m3)concentration"
> "ows_timeformat" "YYYY-MM-DDTHH:MM:SSZ"
> "ows_timeextent" "2011-01-01T00:00:00Z/2012-12-01T00:00:00Z"
> "ows_timedefault" "2011-01-01T00:00:00Z"
> "wms_enable_request" "*"
> "wcs_resolution" "0:10 0:10"
> "wcs_bandcount" "1"
> "wcs_size" "3600 1800"
> layer_name pm25_monthly
> END #METADATA
> PROJECTION
> "init=epsg:4326" #WGS84 Decimal Degrees
> END #PROJECTION
> TILEITEM "location"
> TILEINDEX "pm25_time_index"
> END #LAYER
> Thanks
> mapserver-users at lists.osgeo.org
Andrea Peri
qwerty àèìòù
