[mapserver-users] Setting up a JSONP service
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Jan 13 15:41:27 PST 2015
Hi Lars: Most of what you need was in my last reply. Those are snippets from a working configuration. Here's a simple JSON template for a raster query that creates an array of xyz objects:
// MapServer Template
{'result':{
'points':[
[resultset layer="elev_dem30ra3"]
[feature trimlast=","]{x:[x], y:[y], z:[value_0]},[/feature]
[/resultset]
You could turn this into JSONP and not use the include strategy (I wanted both JSON and JSONP) simply by wrapping the object in callback (callback is a value passed through MapServer, e.g. &mode=query&callback=foo):
// MapServer Template (jsonp.js)
[callback]({'result':{
'points':[
[/resultset]
and here's the corresponding OUTPUTFORMAT block:
OUTPUTFORMAT
NAME 'JSONP'
DRIVER 'TEMPLATE'
MIMETYPE 'application/json;'
FORMATOPTION 'FILE=templates/jsonp.js'
FORMATOPTION 'ATTACHMENT=service.json'
END
Regarding speed, templates are going to be a bit slower since there are generally two passes through the data, once to identify the candidate records and a second for presentation. Also the template assembly is done in memory so there are limits on how large of datasets you can practically work with. How big a deal this is depends on your situation. It's not perfect but in general I've had great luck with this approach.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lars Fricke
Sent: Friday, January 09, 2015 4:24 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Setting up a JSONP service
Hello,
first of all: Thank you for your support!
Sorry for the late reply but I unfortunately was ill.
@ Steve:
I read about templating but also read that it is slower?
I do not have a lot of experience in writing templates. Would you mind sharing a JSONP template?
@ Even: Thank you for your thoughts. Who would implement that change though? I'm afraid I can't.
@ Jeff: I followed those links but I only found threads referring to GeoServer or that were not related to my question. The GDAL page I did study and that's how I managed to set up the GeoJSON service but thats not the same unfortunately as it conflicts with the same origin policy.
Best
Lars
Am 30.12.2014 um 16:24 schrieb Lime, Steve D (MNIT):
> You can also use MapServer templates to accomplish this. It's a little more work since you have to write the template but it's quite flexible then. Usually I write the template to produce JSON and then use a simple wrapper template to produce JSONP. For example, jsonp.js looks like (callback is passed in):
> [callback](
> [include src="templates/json.js"]
> Output formats look like:
> OUTPUTFORMAT
> NAME 'JSON'
> DRIVER 'TEMPLATE'
> FORMATOPTION 'FILE=templates/json.js'
> END
> OUTPUTFORMAT
> NAME 'JSONP'
> DRIVER 'TEMPLATE'
> END
> Steve
> From:mapserver-users-bounces at lists.osgeo.org
> Fricke
> Sent: Monday, December 29, 2014 5:34 AM
> To:mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Setting up a JSONP service
> Dear List,
> I have a WFS service running under MapServer that I would like to operate as JSONP service. I managed to set GEOJSON as output format but I get "Cross-Origin-Request Blocked" if I try to call it with a Javascript client (using Leaflet L.layerJSON.
> The question is: Is it possible to set up a JSONP service from Mapserver and if yes, how? My current mapfile looks like this (relevant parts):
> # in WEB - METADATA
> "wfs_getfeature_formatlist" "geojson,csv,ogrgml"
> OUTPUTFORMAT
> NAME "geojson"
> DRIVER "OGR/GEOJSON"
> MIMETYPE "application/json; subtype=geojson; charset=utf-8"
> FORMATOPTION "STORAGE=stream"
> FORMATOPTION "FORM=SIMPLE"
> FORMATOPTION "LCO:COORDINATE_PRECISION=5"
> END
> If this would already be a correct JSONP service, I have to look on the Leaflet side for the error...
> Thanks for your help.
> Cheers
> Lars
