[mapserver-users] Setting up a JSONP service
Lars Fricke
fricke at gisberater.com
Wed Jan 14 00:34:49 PST 2015
Hi Andreas,
I see. This is what I would need I guess but I'm not getting it. The
"foobar(" and the ");" is missing in my output. I guess I have to go
through my system finding out if potentially an older version of
Mapserver is used instead of the new compilation. I did already
uninstall first but maybe that was not good enough. I even manually
deleted the old mapserv file but it seems something is still wrong
because I get a different output than you even I use the same call.
I'll keep you posted.
Best
Lars
Am 13.01.2015 um 16:52 schrieb Eichner, Andreas - SID:
> That's what I get on the console:
> $ MS_MAPFILE=$(pwd)/IHK_Handelsflaechen.map ./mapserv QUERY_STRING='service=WFS&version=1.1.0&request=GetFeature&featureid=IHK.71247&outputformat=geojson&callback=foobar'Content-Disposition: attachment; filename=result.dat
> Content-Type: application/json; subtype=geojson; charset=utf-8
> foobar({
> "type": "FeatureCollection",
> "features": [
> { "type": "Feature", "properties": { "PLZ": "09648", ..., "LANDKREIS": "Mittelsachsen" }, "geometry": { "type": "Point", "coordinates": [ 4568447.14, 5650577.57 ] } }
> In other words, the JSON is enclosed by "foobar(" and ");": The relevant parts of the mapfile are:
> OUTPUTFORMAT
> NAME 'geojson'
> # NAME 'jsonp'
> DRIVER 'OGR/GEOJSON'
> MIMETYPE 'application/json; subtype=geojson; charset=utf-8'
> # MIMETYPE 'text/javascript; charset=utf-8'
> FORMATOPTION 'STORAGE=stream'
> FORMATOPTION 'FORM=simple'
> FORMATOPTION 'LCO:COORDINATE_PRECISION=5'
> FORMATOPTION 'JSONP=%callback%'
> END
> WEB
> VALIDATION
> callback '.*'
> # default_callback 'jsonp'
> END
> END
> The default value does not work, so the substitution parameter must be given.
>> -----Ursprüngliche Nachricht-----
>> Von: Lars Fricke [mailto:fricke at gisberater.com]
>> Gesendet: Dienstag, 13. Januar 2015 16:39
>> An: Eichner, Andreas - SID; mapserver-users at lists.osgeo.org
>> Betreff: Re: [mapserver-users] Setting up a JSONP service
>> Hi Andreas,
>> I guess I'm still doing something wrong. If I use
>> http://localhost:8082/wfs?SERVICE=WFS&VERSION=1.1.0&request=GetFeature&TYP
>> ENAME=HU&outputformat=geojson&SRS=EPSG:3857&bbox=793732,6570204,793765,657
>> 0228&callback=foobar
>> I'm getting the exact same output as before. What are you getting? Can
>> you post an example of your servers response?
>> Thank you so much.
>> Best
>> Lars
>> Am 13.01.2015 um 15:57 schrieb Eichner, Andreas - SID:
>>> Arg.. outputformat=geojson also works, only had a typo...
>>>> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
>>>> bounces at lists.osgeo.org] Im Auftrag von Eichner, Andreas - SID
>>>> Gesendet: Dienstag, 13. Januar 2015 15:18
>>>> An: 'lars.fricke at skendata.de'; mapserver-users at lists.osgeo.org
>>>> You need to append the "callback" parameter to the query string:
>>>> You can test on the command line, too:
>>>> MS_MAPFILE=/path/to/mapfile ./mapserv
>>>> QUERY_STRING='service=WFS&version=1.1.0&request=GetFeature&typename=HU&
>> SRS=EPSG:3857&bbox=793732,6570204,793765,6570228&outputformat=application/
>>>> json; subtype=geojson; charset=utf-8&callback=foobar'
>>>> Please note that IMHO "geojson" alone isn't enough. The full mimetype
>>>> string should be used as reported by GetCapabilities.
>>>> HTH
>>>>> Gesendet: Dienstag, 13. Januar 2015 14:22
>>>>> Hi,
>>>>> I compiled MapServer after applying the patch (at least I think it was
>>>>> applied). Unfortunately the output is not JSONP format. Maybe I'm
>>>>> getting something wrong. So here is what I did:
>>>>> Applied
>>>>> patch -p1 < jsonp.diff
>>>>> I got an updated mapogroutput.c.
>>>>> I then compiled with the following options:
>>>>> cmake -DCMAKE_INSTALL_PREFIX=/opt \
>>>>> -DCMAKE_PREFIX_PATH="/usr/local;/opt" \
>>>>> -DWITH_CLIENT_WFS=ON \
>>>>> -DWITH_CLIENT_WMS=ON \
>>>>> -DWITH_CURL=ON \
>>>>> -DWITH_SOS=ON \
>>>>> -DWITH_PHP=0 \
>>>>> -DWITH_PYTHON=ON \
>>>>> -DWITH_SVGCAIRO=OFF \
>>>>> -DWITH_ORACLESPATIAL=0 \
>>>>> -DWITH_MSSQL2008=OFF \
>>>>> -DWITH_THREAD_SAFETY=ON \
>>>>> -DWITH_LIBXML2=ON \
>>>>> -DWITH_MYSQL=ON\
>>>>> -DWITH_SDE=0 .. >../configure.out.txt
>>>>> Which goes through without any warning.
>>>>> I do make next, getting a few warnings about the Python bindings but
>>>>> nothing about mapogroutput (ecept that it was compiled). Then sudo
>> make
>>>>> install. No warnings.
>>>>> I then set a symlink to the new mapserv file inside cgi-bin and start
>> my
>>>>> apache.
>>>>> I changed my mapfile as you indicated:
>>>>> WEB
>>>>> FOOTER "test"
>>>>> IMAGEPATH "/var/www/html/tmp/"
>>>>> TEMPPATH "/var/www/html/tmp/"
>>>>> IMAGEURL "/html/tmp/"
>>>>> METADATA
>>>>> "wfs_title" "Test"
>>>>> "ows_onlineresource" "http://localhost:8082/wfs?"
>>>>> "ows_enable_request" "*"
>>>>> "ows_srs" "EPSG:3857"
>>>>> "wfs_srs" "EPSG:3857"
>>>>> "wfs_getfeature_formatlist" "geojson,csv,ogrgml"
>>>>> "wfs_encoding" "UTF-8"
>>>>> END # METADATA
>>>>> VALIDATION
>>>>> callback ".*"
>>>>> END
>>>>> END # WEB
>>>>> OUTPUTFORMAT
>>>>> NAME "geojson"
>>>>> DRIVER "OGR/GEOJSON"
>>>>> MIMETYPE "application/json; subtype=geojson; charset=utf-8"
>>>>> FORMATOPTION "STORAGE=stream"
>>>>> FORMATOPTION "FORM=SIMPLE"
>>>>> FORMATOPTION "LCO:COORDINATE_PRECISION=5"
>>>>> FORMATOPTION "JSONP=%callback%"
>>>>> END
>>>>> Unfortunately calling:
>>>>> 0228
>>>>> gives me a result as before without your changes:
>>>>> "crs": { "type": "name", "properties": { "name":
>>>>> "urn:ogc:def:crs:EPSG::3857" } },
>>>>> "features": [
>>>>> { "type": "Feature", "properties": { "gml_id": "", "UMRING_ID":
>>>>> "36245586"}, "geometry": { "type": "Polygon", "coordinates": [ [ [
>>>>> 793757.73417, 6570202.31642 ], [ 793762.85989, 6570195.63821 ], [
>>>>> 793770.20682, 6570201.30901 ], [ 793765.08276, 6570207.98411 ], [
>>>>> 793757.73417, 6570202.31642 ] ] ] } },
>>>>> "36245583"}, "geometry": { "type": "Polygon", "coordinates": [ [ [
>>>>> 793752.31968, 6570224.89917 ], [ 793747.96097, 6570230.48534 ], [
>>>>> 793732.07033, 6570218.01607 ], [ 793740.12777, 6570207.69188 ], [
>>>>> 793742.99908, 6570209.94649 ], [ 793747.5696, 6570204.08902 ], [
>>>>> 793761.16105, 6570214.75134 ], [ 793752.94726, 6570225.27397 ], [
>>>>> 793752.31968, 6570224.89917 ] ] ] } },
>>>>> "36245550"}, "geometry": { "type": "Polygon", "coordinates": [ [ [
>>>>> 793735.55884, 6570231.00753 ], [ 793738.78194, 6570226.81082 ], [
>>>>> 793746.26949, 6570232.5959 ], [ 793743.04798, 6570236.79266 ], [
>>>>> 793735.55884, 6570231.00753 ] ] ] } }
>>>>> I also tried this with an AJAX call from Javascript, giving me the
>>>>> exactly same result.
>>>>> I get an error message trying to use the result in Leaflet telling me
>> a
>>>>> ";" is missing. I assume it should look like this:
>>>>> var testlayer = [{
>>>>> "features": [
>>>>> I'm not sure what is going on. Am I not applying the changes correctly
>>>>> or is my call wrong?
>>>>> Thanks for you great support.
>>>>> Best
>>>>> Lars
>>>>> Am 09.01.2015 um 15:30 schrieb Eichner, Andreas - SID:
>>>>>> Hi,
>>>>>> I've attached a quick'n dirty solution (against master). When applied
>>>> to
>>>>>> mapogroutput.c you can set a JSONP formatoption to the callback name:
>>>>>> OUTPUTFORMAT
>>>>>> NAME 'geojson'
>>>>>> END
>>>>>> This needs of course a WEB.VALIDATION:
>>>>>> WEB
>>>>>> VALIDATION
>>>>>> callback '.*'
>>>>>> END
>>>>>> END
>>>>>> Would be great if you can test if this works (looks good to me). The
>>>>> Devs might have a look if this could be integrated into master until
>> OGR
>>>>> has an appropriate layer creation option (solution described by Even).
>>>>>> Greetings
>> users-
>>>>>>> bounces at lists.osgeo.org] Im Auftrag von Lars Fricke
>>>>>>> Gesendet: Freitag, 9. Januar 2015 11:24
>>>>>>> An: mapserver-users at lists.osgeo.org
>>>>>>> Hello,
>>>>>>> first of all: Thank you for your support!
>>>>>>> Sorry for the late reply but I unfortunately was ill.
>>>>>>> @ Steve:
>>>>>>> I read about templating but also read that it is slower?
>>>>>>> I do not have a lot of experience in writing templates. Would you
>>>> mind
>>>>>>> sharing a JSONP template?
>>>>>>> @ Even: Thank you for your thoughts. Who would implement that change
>>>>>>> though? I'm afraid I can't.
>>>>>>> @ Jeff: I followed those links but I only found threads referring to
>>>>>>> GeoServer or that were not related to my question. The GDAL page I
>>>> did
>>>>>>> study and that's how I managed to set up the GeoJSON service but
>>>> thats
>>>>>>> not the same unfortunately as it conflicts with the same origin
>>>> policy.
>>>>>>> Best
>>>>>>> Lars
>>>>>>> Am 30.12.2014 um 16:24 schrieb Lime, Steve D (MNIT):
>>>>>>>> You can also use MapServer templates to accomplish this. It's a
>>>> little
>>>>>>> more work since you have to write the template but it's quite
>>>> flexible
>>>>>>> then. Usually I write the template to produce JSON and then use a
>>>>> simple
>>>>>>> wrapper template to produce JSONP. For example, jsonp.js looks like
>>>>>>> (callback is passed in):
>>>>>>>> // MapServer Template
>>>>>>>> [callback](
>>>>>>>> [include src="templates/json.js"]
>>>>>>>> Output formats look like:
>>>>>>>> OUTPUTFORMAT
>>>>>>>> NAME 'JSON'
>>>>>>>> DRIVER 'TEMPLATE'
>>>>>>>> MIMETYPE 'application/json;'
>>>>>>>> FORMATOPTION 'FILE=templates/json.js'
>>>>>>>> FORMATOPTION 'ATTACHMENT=service.json'
>>>>>>>> END
>>>>>>>> OUTPUTFORMAT
>>>>>>>> NAME 'JSONP'
>>>>>>>> DRIVER 'TEMPLATE'
>>>>>>>> FORMATOPTION 'FILE=templates/jsonp.js'
>>>>>>>> END
>>>>>>>> Steve
>>>>>>>> -----Original Message-----
>>>>>>>> From:mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-
>>>> users-
>>>>>>> bounces at lists.osgeo.org] On Behalf Of Lars Fricke
>>>>>>>> Sent: Monday, December 29, 2014 5:34 AM
>>>>>>>> To:mapserver-users at lists.osgeo.org
>>>>>>>> Subject: [mapserver-users] Setting up a JSONP service
>>>>>>>> Dear List,
>>>>>>>> I have a WFS service running under MapServer that I would like to
>>>>>>> operate as JSONP service. I managed to set GEOJSON as output format
>>>> but
>>>>> I
>>>>>>> get "Cross-Origin-Request Blocked" if I try to call it with a
>>>>> Javascript
>>>>>>> client (using Leaflet L.layerJSON.
>>>>>>>> The question is: Is it possible to set up a JSONP service from
>>>>> Mapserver
>>>>>>> and if yes, how? My current mapfile looks like this (relevant
>> parts):
>>>>>>>> # in WEB - METADATA
>>>>>>>> OUTPUTFORMAT
>>>>>>>> NAME "geojson"
>>>>>>>> END
>>>>>>>> If this would already be a correct JSONP service, I have to look on
>>>>> the
>>>>>>> Leaflet side for the error...
>>>>>>>> Thanks for your help.
>>>>>>>> Cheers
>>>>>>>> Lars
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
