[mapserver-users] FW: Errors about mapcache configure in apache httpd
Mathieu Coudert
mathieu.coudert at gmail.com
Wed Jan 14 02:01:59 PST 2015
I would suggest you to check/update your shared libraries after compiling
MapCache...
You will find more info there :
http://unix.stackexchange.com/questions/67781/use-shared-libraries-in-usr-local-lib
Cheers,
Mathieu
On Wed, Jan 14, 2015 at 2:12 AM, 刘小二 <liuxiaoer at live.cn> wrote:
> Hi, list:
> I had succeeded in compiling and installing the mapcache according to the
> guide <http://mapserver.org/mapcache/install.html>, but there was
> something wrong with integrating mod_mapcache.so to apache httpd. The
> following is my logs about compiling and installing and httpd conf file.
> mapcache.conf
> <IfModule !mapcache_module>
> LoadModule mapcache_module modules/mod_apreq2.so
> </IfModule>
> #<Directory /var/www/mapcache>
> # Require all granted
> #</Directory>
> #MapCacheAlias /mapcache "/var/www/mapcache/mapcache.xml"
> [root at localhost build]# systemctl status httpd.service -l
> httpd.service - The Apache HTTP Server
> Loaded: loaded (/usr/lib/systemd/system/httpd.service; disabled)
> Active: failed (Result: exit-code) since 三 2015-01-14 08:19:05 CST; 7s
> ago
> Process: 29697 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited,
> status=0/SUCCESS)
> Process: 29695 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND
> (code=exited, status=1/FAILURE)
> Main PID: 29695 (code=exited, status=1/FAILURE)
> Status: "Total requests: 0; Current requests/sec: 0; Current traffic:
> 0 B/sec"
> 1月 14 08:19:05 localhost.localdomain httpd[29695]: httpd: Syntax error on
> line 56 of /etc/httpd/conf/httpd.conf: Syntax error on line 6 of
> /etc/httpd/conf.modules.d/10-mp-.conf: Cannot load modules/mod_mapcache.so
> into server: libmapcache.so.1: cannot open shared object file: No such file
> or directory
> 1月 14 08:19:05 localhost.localdomain systemd[1]: httpd.service: main
> process exited, code=exited, status=1/FAILURE
> 1月 14 08:19:05 localhost.localdomain systemd[1]: Failed to start The
> Apache HTTP Server.
> 1月 14 08:19:05 localhost.localdomain systemd[1]: Unit httpd.service
> entered failed state.
> Any advice will be appreciated.
> Regards,
> liuxiaoer
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150114/552feef7/attachment.html>
