[mapserver-users] mapserver - postgis/postgresql connection problem
kassandraxx
eleonora at creativalab.com
Wed Jan 14 05:58:34 PST 2015
Hello!
http://archeogis.myftp.org/pmapper-4.2.0/map_default.phtml
in this example, I can see the data uploaded to the ftp, but I can not see
the data uploaded to the database ( ager Firmanus ) .
In QGIS i can add postgis vector data, then the database is working
properly.
This is part of my map file
LAYER
NAME 'Ager Firmanus'
TYPE LINE
DUMP true
TEMPLATE void
EXTENT 325018.498153 4739346.182159 402747.056951 4777108.180989
CONNECTIONTYPE postgis
CONNECTION "dbname='db_name' host=archeogis.myftp.org port=5432
user='xxx' password='xxx' sslmode=disable"
DATA 'the_geom FROM "ager_firmanus" USING UNIQUE gid USING srid=32633'
METADATA
'ows_title' 'ager_firmanus'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
CLASS
NAME 'ager_firmanus'
STYLE
WIDTH 1
COLOR 77 158 104
END
END
END
Table ager_firmanus
gid Id the_geom
1 0 0102000020797F0000FE0000004979E20BBB4A1841014A22E...
table geometry_columns
f_table_catalog f_table_schema f_table_name f_geometry_column
coord_dimension srid type
db_name public ager_firmanus the_geom
2 32633 LINESTRING
I can not understand where is the error :(
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapserver-postgis-postgresql-connection-problem-tp5181475.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
