[mapserver-users] mapserver - postgis/postgresql connection problem
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Jan 14 06:30:00 PST 2015
At least your DATA, EXTENT and PROJECTION do not match. You define the projection of the layer as EPSG:4326 but I guess that it EPSG:32633. TRANSPARENCY 100 means totally transparent map so even if it happens to work you can't notice it. Then I am not sure if pmapper can turn the status of the layer from OFF to ON. However, I am sure that starting testing with an application is never a good idea. Test first with shp2img http://mapserver.org/utilities/shp2img.html and you can avoid the troubles caused by http server and misconfigured client. Once you can see that you map works with shp2img you can continue.
It would be good to see your whole mapfile. If you have created it with the QGIS plugin it will not work without some more edits.
-Jukka Rahkonen-
kassandraxx wrote:
> Hello!
> http://archeogis.myftp.org/pmapper-4.2.0/map_default.phtml
> in this example, I can see the data uploaded to the ftp, but I can not see the data uploaded to the database ( ager Firmanus ) .
In QGIS i can add postgis vector data, then the database is working properly.
> This is part of my map file
LAYER
NAME 'Ager Firmanus'
TYPE LINE
DUMP true
TEMPLATE void
EXTENT 325018.498153 4739346.182159 402747.056951 4777108.180989
CONNECTIONTYPE postgis
CONNECTION "dbname='db_name' host=archeogis.myftp.org port=5432 user='xxx' password='xxx' sslmode=disable"
DATA 'the_geom FROM "ager_firmanus" USING UNIQUE gid USING srid=32633'
METADATA
'ows_title' 'ager_firmanus'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
CLASS
NAME 'ager_firmanus'
STYLE
WIDTH 1
COLOR 77 158 104
END
END
END
Table ager_firmanus
gid Id the_geom
1 0 0102000020797F0000FE0000004979E20BBB4A1841014A22E...
table geometry_columns
f_table_catalog f_table_schema f_table_name f_geometry_column
coord_dimension srid type
db_name public ager_firmanus the_geom
2 32633 LINESTRING
I can not understand where is the error :(
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapserver-postgis-postgresql-connection-problem-tp5181475.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
