[mapserver-users] mapserver - postgis/postgresql connection problem
kassandraxx
eleonora at creativalab.com
Wed Jan 14 07:37:35 PST 2015
thanks so much for your advice, unfortunately, are still inexperienced. :(
my project and my files are based on wgs84 utm 33N
I checked all extend with ogrinfo and I corrected
then I tried as you suggested to use shp2img on my map file and this is the
error that comes back:
msDrawMap(): Image handling error. Failed to draw layer named 'Ager
Firmanus'. <br>
msPostGISLayerWhichShapes(): Query error. Error (ERROR: function
geomfromtext(u nknown, integer) does not exist
LINE 1: ...geom,"gid" from "ager_firmanus" where the_geom && GeomFromTe...
HINT: No function matches the given name and argument types. You might need
to add explicit type casts.
) executing query: select
encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex
') as geom,"gid" from "ager_firmanus" where the_geom &&
GeomFromText('POLYGON((2 52691.191155437
4727437.25648659,252691.191155437 4871219.56915799,425287.594538
208 4871219.56915799,425287.594538208 4727437.25648659,252691.191155437
4727437. 25648659))',32633) <br>
this is my whole file map
MAP
EXTENT 266351.432505 4727437.256493 411627.353192 4871219.569158
IMAGECOLOR 255 255 255
UNITS meters
SIZE 600 500
SHAPEPATH "/var/www/data"
SYMBOLSET "../common/symbols/symbols-pmapper.sym"
FONTSET "../common/fonts/msfontset.txt"
RESOLUTION 96
IMAGETYPE png
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
# Start of web interface definition
WEB
TEMPLATE "map.html"
IMAGEPATH "/var/www/tmp/"
IMAGEURL "/tmp/"
END # Web
# Start of Reference map definition
REFERENCE
IMAGE "../../images/reference.png"
SIZE 229 149
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END # Reference
# Start of legend
LEGEND
KEYSIZE 20 20
LABEL
TYPE TRUETYPE
FONT "georgia"
SIZE 11
COLOR 200 50 0
END
STATUS ON
END
SCALEBAR
LABEL
COLOR 0 0 0
SIZE small
END
STYLE 1
SIZE 350 10
COLOR 0 0 125
UNITS KILOMETERS
INTERVALS 4
TRANSPARENT FALSE
STATUS ON
END # Scalebar object ends
# Start of querymap
QUERYMAP
SIZE 200 150
STATUS ON
STYLE SELECTED
COLOR 255 0 0
END
#================== START OF LAYER SECTION =====================#
LAYER # States polygon layer begins here
NAME "Marche"
TEMPLATE void
DATA "marche"
STATUS OFF
TYPE POLYGON
METADATA
"ows_title" "marche"
END # Metadata
CLASS
NAME "marche"
STYLE
COLOR 200 254 199
END
END
END # States polygon layer ends here
LAYER
NAME "Comuni"
TYPE POLYGON
DUMP true
TEMPLATE void
EXTENT 354559.923623 4741968.996931 380152.627473 4767524.906967
DATA "comuni_ricerca"
METADATA
'ows_title' 'comuni_ricerca'
END
STATUS OFF
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
CLASSITEM 'NOME_COM'
CLASS
NAME "Amandola"
EXPRESSION "Amandola"
STYLE
WIDTH 1
OUTLINECOLOR 0 0 0
COLOR 90 218 71
END
END
CLASS
NAME "Comunanza"
EXPRESSION "Comunanza"
STYLE
WIDTH 1
OUTLINECOLOR 0 0 0
COLOR 204 163 11
END
END
CLASS
NAME "Montefalcone Appennino"
EXPRESSION "Montefalcone Appennino"
STYLE
WIDTH 1
OUTLINECOLOR 0 0 0
COLOR 59 114 249
END
END
CLASS
NAME "Montefortino"
EXPRESSION "Montefortino"
STYLE
WIDTH 1
OUTLINECOLOR 0 0 0
COLOR 211 131 138
END
END
CLASS
NAME "Montemonaco"
EXPRESSION "Montemonaco"
STYLE
WIDTH 1
OUTLINECOLOR 0 0 0
COLOR 77 182 62
END
END
CLASS
NAME "Santa Vittoria in Matenano"
EXPRESSION "Santa Vittoria in Matenano"
STYLE
WIDTH 1
OUTLINECOLOR 0 0 0
COLOR 88 128 122
END
END
CLASS
NAME "Smerillo"
EXPRESSION "Smerillo"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 53 149 170
END
END
END
LAYER
NAME "Cittadine"
TYPE POINT
DUMP true
TEMPLATE void
EXTENT 365500.628492 4757245.000969 370593.603261 4759482.322111
DATA "citta"
METADATA
'ows_title' 'citta'
END
STATUS OFF
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
CLASS
NAME 'citta'
STYLE
SYMBOL "circle"
SIZE 7.0
OUTLINECOLOR 0 0 0
COLOR 214 205 104
END
END
END
LAYER
NAME "Idrografia"
TYPE LINE
DUMP true
TEMPLATE void
EXTENT 355646.233379 4743380.868410 380147.958386 4767436.959607
DATA "idrografia_clip"
METADATA
'ows_title' 'idrografia_clip'
END
STATUS OFF
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
CLASS
NAME 'idrografia_clip'
STYLE
WIDTH 1
COLOR 146 190 255
END
END
END
LAYER
NAME "Curve di livello"
TYPE LINE
DUMP true
TEMPLATE void
EXTENT 354562.132679 4741970.274523 380150.652637 4767491.845169
DATA "isoipse_clip"
METADATA
'ows_title' 'isoipse_clip'
END
STATUS OFF
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
CLASS
NAME 'isoipse_clip'
STYLE
WIDTH 1
COLOR 237 237 237
END
END
END
LAYER
NAME "Strade"
TYPE LINE
DUMP true
TEMPLATE void
EXTENT 354639.299023 4742245.805300 379951.835356 4767409.867252
DATA "viabilita_clip"
METADATA
'ows_title' 'viabilita_clip'
END
STATUS OFF
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
CLASS
NAME 'viabilita_clip'
STYLE
WIDTH 0.10
COLOR 0 0 0
END
END
END
NAME "Edifici"
DATA "edifici"
DUMP true
TEMPLATE void
EXTENT 357707.023218 4756331.869061 377721.396435 4767017.463077
STATUS OFF
TYPE POLYGON
METADATA
"ows_title" "edifici"
END # Metadata
CLASS
NAME "edifici"
STYLE
COLOR 156 156 156
END
END
LAYER
NAME 'Ager Firmanus'
TYPE LINE
DUMP true
TEMPLATE void
EXTENT 373783.754747 4759872.638913 405743.922708 4794307.658343
CONNECTIONTYPE postgis
CONNECTION "dbname='db_name' host=archeogis.myftp.org port=5432
user='xxx' password='xxx' sslmode=disable"
DATA 'the_geom FROM "ager_firmanus" USING UNIQUE gid USING srid=32633'
METADATA
'ows_title' 'ager_firmanus'
END
STATUS ON
PROJECTION
'proj=utm'
'zone=33'
'datum=WGS84'
'units=m'
'no_defs'
END
CLASS
NAME 'ager_firmanus'
STYLE
WIDTH 10
COLOR 77 158 104
END
END
END
END #Map
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapserver-postgis-postgresql-connection-problem-tp5181475p5181502.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
