[mapserver-users] Set LABELANGLE [attribute] via Mapscript (6.41)
Fergus McDonald
mapserver at schartz.net
Thu Jan 22 11:06:35 PST 2015
I think it should at least say that the angle attribute of the object is
the equivalent of the "ANGLE double" form in the map
file LABEL declaration. Whereas, the "ANGLE [attribute]" form is
implemented using the setBinding() method, and "ANGLE
[auto|auto2|follow]" forms I assume are done using combinations of the
autoangle and autofollow attributes, but more documentation would be
helpful.
On Thu, 22 Jan 2015 15:51:56 +0100
Håvard Tveite <havard.tveite at nmbu.no> wrote:
> I would have thought that instead of "TODO" it should repeat the
> information on Angle in http://mapserver.org/mapfile/label.html.
> I can try to update the documentation, but I need someone to tell
> me what to write.
> Håvard
> On 2015-01-22 15:16, Fergus McDonald wrote:
> > angle is mentioned as an attribute here, with a "TODO"
> > http://mapserver.org/mapscript/mapscript.html#labelobj
> > It doesn't specially say there is a setAngle() method, but you can
> > see is exists in the generated code.
> > On Thu, 22 Jan 2015 12:56:00 +0100
> >> Hi,
> >> I am not able to find anything about labelObj.setAngle() in
> >> the current Mapserver docs. Could you point me in the right
> >> direction?
> >> Håvard
> >> On 2015-01-18 16:27, Fergus McDonald wrote:
> >>> Thanks Steve.. that was it. I was able to set it using (in Java):
> >>> setBinding(MS_LABEL_BINDING_ENUM.MS_LABEL_BINDING_ANGLE.swigValue(),
> >>> strAngleAttribute);
> >>> It would be good maybe if there was a hint about this in the docs
> >>> for labelObj.setAngle()
> >>> On Fri, 16 Jan 2015 22:06:54 +0000
> >>> "Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us> wrote:
> >>>> I believe it's done with the setBinding method. Labels and styles
> >>>> have that method.
> >>>> Steve
> >>>> -----Original Message-----
> >>>> From: mapserver-users-bounces at lists.osgeo.org
> >>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> >>>> Fergus McDonald Sent: Friday, January 16, 2015 8:54 AM To:
> >>>> mapserver-users at lists.osgeo.org Subject: [mapserver-users] Set
> >>>> I might be missing something in the docs, but how does one set
> >>>> the labelangle for a mapscript labelObj to an attribute name, the
> >>>> equivalent of ANGLE [attribute] in the LABEL declaration of the
> >>>> MAP file?
> >>>> The angle property of labelObj can only be a float value.
> >>>> The layer object has a labelangleitem property mentioned in the
> >>>> main docs, but the "PHP Mapscript Migration Guide" says that this
> >>>> property was removed as of version 6.
> >>>> _______________________________________________ mapserver-users
> >>>> mailing list mapserver-users at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> >>> mapserver-users mailing list
