[mapserver-users] Mapserver doesn't send good filter to postgis
Steve.Toutant at inspq.qc.ca
Mon Jan 26 08:15:11 PST 2015
sorry I'm confused, perhaps I misunderstand what you explained. I don't
understand what you mean by "MapServer does use the supplied geometry,
it?s a matter of where the filter is applied ? the database or in
MapServer"
In mapserver log I see
FLTLayerApplyPlainFilterToLayer(): ([shape] within fromText('POLYGON
((-8081644.2511243997141719 5835062.5699599999934435,
-8081707.5505384001880884 5834980.1612889003008604,
-8081638.2794815003871918 5834913.2788891997188330,
-8081533.1785677000880241 5834988.5215889001265168,
-8081644.2511243997141719 5835062.5699599999934435))'))
So this is good, but
A few lines later in the mapserver log, I see that it is not sending the
supplied geometry as filter, it is sending the extent of the mapfile
select ....... where geom_p && ST_GeomFromText('POLYGON((-9239517
5465442,-9239517 9349764,-5565974 9349764,-5565974 5465442,-9239517
5465442))',3857);
So it received the supplied geometry, but it is not using it....
If only BBOX can be used as a spatial operator, it is not good for our
needs. We really need to know what features are inside a user defined
polygon.
"Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us>
2015-01-26 10:56
A
"Steve.Toutant at inspq.qc.ca" <Steve.Toutant at inspq.qc.ca>
cc
"mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Objet
RE: [mapserver-users] Mapserver doesn't send good filter to postgis
MapServer does use the supplied geometry, it?s a matter of where the
filter is applied ? the database or in MapServer. This isn?t a new
limitation so others may have more experience with workarounds. Maybe try
also setting a bbox in the filter based on the bbox of the geometry?
Steve
From: Steve.Toutant at inspq.qc.ca [mailto:Steve.Toutant at inspq.qc.ca]
Sent: Monday, January 26, 2015 9:38 AM
To: Lime, Steve D (MNIT)
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Mapserver doesn't send good filter to
postgis
I understand the objective of rfc 91, but the most common use case would
be to pass the supplied geometry.....
If mapserver doesn't use the supplied geometry, that means that it doesn't
support spatial filtering.
Our data covers the whole country, not using the supplied geometry means
we can't use mapserver as a wfs server....
Is there something we can do about it? A workaround we could use?
2015-01-26 10:14
A
"Steve.Toutant at inspq.qc.ca" <Steve.Toutant at inspq.qc.ca>, "
cc
Objet
It?s a limitation in older versions of MapServer where specific backend
optimizations were scattered about the WMS/WFS code. Most of those
optimizations address the most common use cases ? I guess this wasn?t one
of them. It?s surprising that at worst the extent of the supplied geometry
isn?t passed (I see a comment in the WFS code about this). The specific
filter intersection test is applied on the MapServer side ? the results
are correct, performance can suffer though.
This is being addresses in MapServer 7.0 where more complete filter
translation functions are being supported (RFC 91).
Steve
mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
Sent: Monday, January 26, 2015 8:55 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Mapserver doesn't send good filter to postgis
Sorry my first post was with an inapprpriate title......
I'm using mapserver 6.4.1 and postgis 2.1
using OpenLayers 2.13.1 I draw a small polygon that I use for a within
spatial filter of a WFS getfeature request. The problem is that mapserver
is not sending this polygon to postgis, it is sending the extent of the
mapfile as filter...
The wfs POST Request (created and send by OpenLayers client)
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc
"><ogc:Within><ogc:PropertyName>msGeometry</ogc:PropertyName><gml:Polygon
xmlns:gml="http://www.opengis.net/gml"
srsName="urn:ogc:def:crs:EPSG::3857"><gml:exterior><gml:LinearRing><gml:posList>-8081644.2511244
5835062.56996 -8081707.5505384 5834980.1612889 -8081638.2794815
5834913.2788892 -8081533.1785677 5834988.5215889 -8081644.2511244
5835062.56996</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></ogc:Within></ogc:Filter>
In Mapserver log, I see
Then a few lines later, I see that it is not sending the polygon received
as filter
5465442))',3857);
See the polygon definition is different, postgis receive the extent
defined in the mapfile
EXTENT -9239517 5465442 -5565974 9349764
And, in postgis log I see this query, See the
5465442))',3857);
Why Mapserver is not sending the polygon received as filter to postgis?
Thanks!
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction de la santé environnementale et de la toxicologie
Institut national de santé publique du Québec
Tél.: 418 646-6777 poste 30015
Téléc.: 418 644-4593
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
http://www.monclimatmasante.qc.ca
Pour me rejoindre par courrier
Service de l'infrastructure et du réseau
Direction des technologies de l'information
Ministère de la Sécurité Publique
2525 boul. Laurier, 2e étage
Tour Laurentides
Québec, G1V 2L2
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150126/f41230c0/attachment-0001.html>
