[mapserver-users] Mapserver doesn't send good filter to postgis
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jan 26 08:31:41 PST 2015
Steve T.,
mapserver gets back all the geometries from postgis and then filters
them in mapserver against the geometry.
Mapserver passes the BBOX for the mapfile to postgis as you noticed
which is not very efficient, but you can override that to the BBOX of
the window using the BBOX substitution variable in the SQL, but this
might not be what you want if you geometry is off screen.
I'm not aware of any way to pass the BBOX of the geometry.
Steve L - can we do this?
So currently, your wfs requests are getting filtered against the
geometry. And there is room for efficiency improvements.
-Steve W
On 1/26/2015 11:15 AM, Steve.Toutant at inspq.qc.ca wrote:
> sorry I'm confused, perhaps I misunderstand what you explained. I don't
> understand what you mean by "MapServer does use the supplied geometry,
> it’s a matter of where the filter is applied – the database or in
> MapServer"
> In mapserver log I see
> FLTLayerApplyPlainFilterToLayer(): ([shape] within fromText('POLYGON
> ((-8081644.2511243997141719 5835062.5699599999934435,
> -8081707.5505384001880884 5834980.1612889003008604,
> -8081638.2794815003871918 5834913.2788891997188330,
> -8081533.1785677000880241 5834988.5215889001265168,
> -8081644.2511243997141719 5835062.5699599999934435))'))
> So this is good, but
> A few lines later in the mapserver log, I see that it is not sending the
> supplied geometry as filter, it is sending the extent of the mapfile
> select ....... where geom_p && ST_GeomFromText('POLYGON((-9239517
> 5465442,-9239517 9349764,-5565974 9349764,-5565974 5465442,-9239517
> 5465442))',3857);
> So it received the supplied geometry, but it is not using it....
> If only BBOX can be used as a spatial operator, it is not good for our
> needs. We really need to know what features are inside a user defined
> polygon.
> *"Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us>*
> 2015-01-26 10:56
> A
> "Steve.Toutant at inspq.qc.ca" <Steve.Toutant at inspq.qc.ca>
> cc
> "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
> Objet
> RE: [mapserver-users] Mapserver doesn't send good filter to postgis
> MapServer does use the supplied geometry, it’s a matter of where the
> filter is applied – the database or in MapServer. This isn’t a new
> limitation so others may have more experience with workarounds. Maybe
> try also setting a bbox in the filter based on the bbox of the geometry?
> Steve
> *From:* Steve.Toutant at inspq.qc.ca [mailto:Steve.Toutant at inspq.qc.ca] *
> Sent:* Monday, January 26, 2015 9:38 AM*
> To:* Lime, Steve D (MNIT)*
> Cc:* mapserver-users at lists.osgeo.org*
> Subject:* RE: [mapserver-users] Mapserver doesn't send good filter to
> postgis
> I understand the objective of rfc 91, but the most common use case would
> be to pass the supplied geometry.....
> If mapserver doesn't use the supplied geometry, that means that it
> doesn't support spatial filtering.
> Our data covers the whole country, not using the supplied geometry means
> we can't use mapserver as a wfs server....
> Is there something we can do about it? A workaround we could use?
> *"Lime, Steve D (MNIT)" <**_Steve.Lime at state.mn.us_*
> <mailto:Steve.Lime at state.mn.us>*>*
> 2015-01-26 10:14
> A
> "_Steve.Toutant at inspq.qc.ca_ <mailto:Steve.Toutant at inspq.qc.ca>"
> <_Steve.Toutant at inspq.qc.ca_ <mailto:Steve.Toutant at inspq.qc.ca>>,
> "_mapserver-users at lists.osgeo.org_
> <mailto:mapserver-users at lists.osgeo.org>"
> <_mapserver-users at lists.osgeo.org_
> <mailto:mapserver-users at lists.osgeo.org>>
> cc
> Objet
> It’s a limitation in older versions of MapServer where specific backend
> optimizations were scattered about the WMS/WFS code. Most of those
> optimizations address the most common use cases – I guess this wasn’t
> one of them. It’s surprising that at worst the extent of the supplied
> geometry isn’t passed (I see a comment in the WFS code about this). The
> specific filter intersection test is applied on the MapServer side – the
> results are correct, performance can suffer though.
> This is being addresses in MapServer 7.0 where more complete filter
> translation functions are being supported (RFC 91).
> Steve
> From:* _mapserver-users-bounces at lists.osgeo.org_
> <mailto:mapserver-users-bounces at lists.osgeo.org>
> [_mailto:mapserver-users-bounces at lists.osgeo.org_] *On Behalf Of
> *_Steve.Toutant at inspq.qc.ca_ <mailto:Steve.Toutant at inspq.qc.ca>*
> Sent:* Monday, January 26, 2015 8:55 AM*
> To:* _mapserver-users at lists.osgeo.org_
> <mailto:mapserver-users at lists.osgeo.org>*
> Subject:* [mapserver-users] Mapserver doesn't send good filter to postgis
> Sorry my first post was with an inapprpriate title......
> I'm using mapserver 6.4.1 and postgis 2.1
> using OpenLayers 2.13.1 I draw a small polygon that I use for a within
> spatial filter of a WFS getfeature request. The problem is that
> mapserver is not sending this polygon to postgis, it is sending the
> extent of the mapfile as filter...
> The wfs POST Request (created and send by OpenLayers client)
> <ogc:Filter
> xmlns:ogc="_http://www.opengis.net/ogc_"><ogc:Within><ogc:PropertyName>msGeometry</ogc:PropertyName><gml:Polygon
> xmlns:gml="_http://www.opengis.net/gml_"
> srsName="urn:ogc:def:crs:EPSG::3857"><gml:exterior><gml:LinearRing><gml:posList>-8081644.2511244
> 5835062.56996 -8081707.5505384 5834980.1612889 -8081638.2794815
> 5834913.2788892 -8081533.1785677 5834988.5215889 -8081644.2511244
> 5835062.56996</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></ogc:Within></ogc:Filter>
> In Mapserver log, I see
> Then a few lines later, I see that it is not sending the polygon
> received as filter
> 5465442))',3857);
> See the polygon definition is different, postgis receive the extent
> defined in the mapfile
> EXTENT -9239517 5465442 -5565974 9349764
> And, in postgis log I see this query, See the
> 5465442))',3857);
> Why Mapserver is not sending the polygon received as filter to postgis?
> Thanks!
> /Steve Toutant, M. Sc./
> Analyste en géomatique
> Secteur environnement
> Direction de la santé environnementale et de la toxicologie
> Institut national de santé publique du Québec
> Tél.: 418 646-6777 poste 30015
> Téléc.: 418 644-4593_
> __steve.toutant at inspq.qc.ca_ <mailto:steve.toutant at inspq.qc.ca>_
> __http://www.inspq.qc.ca_ <http://www.inspq.qc.ca/>_
> __http://www.monclimatmasante.qc.ca_ <http://www.monclimatmasante.qc.ca/>
> /Pour me rejoindre par courrier/
> Service de l'infrastructure et du réseau
> Direction des technologies de l'information
> Ministère de la Sécurité Publique
> 2525 boul. Laurier, 2e étage
> Tour Laurentides
> Québec, G1V 2L2
