[mapserver-users] determining which map file is associated with which fast-cgi process
Richard Greenwood
richard.greenwood at gmail.com
Tue Jul 28 08:06:05 PDT 2015
Renzo and Eichner,
Thanks you for your answers. I have a much better understanding now. I was
clearly wrong in my assumption that each mapserv.fcgi process related to a
single map file. I appreciate your help.
Rich
On Tue, Jul 28, 2015 at 7:12 AM, Eichner, Andreas - SID <
Andreas.Eichner at sid.sachsen.de> wrote:
> For each request a MapServer FCGI process uses either the value of the
> map= query parameter or the value of the MS_MAPFILE environment variable.
> In most configurations a pool of those processes is used to work on
> multiple requests simultaneously. Essentially there's no fixed association
> between a FCGI process and a map file.
> > -----Ursprüngliche Nachricht-----
> > Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> > bounces at lists.osgeo.org] Im Auftrag von Richard Greenwood
> > Gesendet: Montag, 27. Juli 2015 23:28
> > An: mapserver
> > Betreff: [mapserver-users] determining which map file is associated with
> > This is probably a more general Linux or fast-cgi question than strictly
> > mapserver, but I don't know where else to ask so I'll give it a try here.
> > I'm serving several different map files and I have several fast-cgi
> > mapserv instances.
> > Am I correct that each mapserv.fcgi is serving a different map file and
> > that all mapserv requests for given map file go to the same fcig
> instance?
> > And if I'm correct on that, when I use commands like 'top' or 'ps' they
> > all show as mapserv.fcgi. I'd like to know which instance is serving
> which
> > map file.
> > Thanks,
> > Rich
> > Richard W. Greenwood, PLS
> > www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150728/1832f7c9/attachment.html>
