[mapserver-users] determining which map file is associated with which fast-cgi process
Renzo Kottmann
rkottman at mpi-bremen.de
Tue Jul 28 03:11:32 PDT 2015
I do not have a fast.cgi configuration. But if your assumption is
correct then each instance should keep a file handle on the mapfiles and
then you can see which process is accessing which files with the
command: lsof (list open files).
hope it helps,renzo
On 2015-07-27 23:28, Richard Greenwood wrote:
> This is probably a more general Linux or fast-cgi question than strictly
> mapserver, but I don't know where else to ask so I'll give it a try
> here. I'm serving several different map files and I have several
> fast-cgi mapserv instances.
> Am I correct that each mapserv.fcgi is serving a different map file and
> that all mapserv requests for given map file go to the same fcig instance?
> And if I'm correct on that, when I use commands like 'top' or 'ps' they
> all show as mapserv.fcgi. I'd like to know which instance is serving
> which map file.
> Thanks,
> Rich
> Richard W. Greenwood, PLS
> www.greenwoodmap.com <http://www.greenwoodmap.com>
> mapserver-users at lists.osgeo.org
Renzo Kottmann PhD
Senior Scientist at
Max Planck Institute for Marine Microbiology
Microbial Genomics and Bioinformatics Research Group
Celsiusstr. 1
28359 Bremen
Germany
Phone: +49 421 2028 974
