[mapserver-users] Accessing ArcSDE on secured site
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jun 8 13:59:04 PDT 2015
I don't have your answer, but I would try to connect through GDAL
(ogrinfo command) to your SDE instance, and then report your commandline
syntax and error to the community. Since I notice that GDAL 2.0.0 is
almost released, you might try to send your feedback and questions
direct to the GDAL community as well (might be good timing to get a
change done in GDAL for SDE). And of course if you have funding
available to help create your change, be sure to mention that in your
message. Thanks,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2015-06-08 5:16 PM, Weisbender, Eric wrote:
> Hello,
> A couple of weeks about I posted the question below and hear anything.
> I was wondering if it went through and if anyone had any insight.
> I am trying to access ArcSDE with mapserver on a secured site that uses
> https:// not http. I keep getting an error saying Server Not Found. Is
> this even possible and if so I would welcome any help. Thanks in advance.
> Eric
