[mapserver-users] Incompatibility at Filter - level between mapserver 6.x and the last mapserver-dev ?
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Tue Jun 9 02:06:06 PDT 2015
I think you should use
FILTER "([CODICE] = 107)"
i.e. without using FILTERITEM and the leading WHERE
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> bounces at lists.osgeo.org] Im Auftrag von Andrea Peri
> Gesendet: Dienstag, 9. Juni 2015 10:45
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] Incompatibility at Filter - level between
> Hi,
> I have just update my mapserver to the last mapserver-dev .
> After this update, I see an error on the filtering.
> In my mapfile the data configuration was originally this:
> CONNECTION "/path-to-spatialite-db/zz_db_tematici.sqlite"
> CONNECTIONTYPE OGR
> DATA "IFT2009"
> EXTENT 1554650.74 4678225.52 1771822.76 4924891.9
> FILTER "WHERE ([CODICE] = 107)"
> FILTERITEM "CODICE"
> The log report this error:
> [Tue Jun 9 10:39:46 2015].153296 msDrawMap(): rendering using
> outputformat named AGGA (AGG/PNG).
> [Tue Jun 9 10:39:46 2015].154698 msDrawMap(): WMS/WFS set-up and query,
> 0.001s
> [Tue Jun 9 10:39:46 2015].262330 LayerDefaultTranslateFilter():
> General error message. This data driver does not implement filter
> translation support
> [Tue Jun 9 10:39:46 2015].282402 msDrawMap(): Layer 239
> (rt_ucs.idift.rt.107), 0.128s
> [Tue Jun 9 10:39:46 2015].282550 msDrawMap(): Drawing Label Cache, 0.000s
> I'm using spatialite as db.
> After this error, I read this RFC:
> http://www.mapserver.org/ru/development/rfc/ms-rfc-91.html
> And try the new settings,
> FILTER (([FILTERITEM[ = "string") AND (CODICE = 107))
> but it seem don't work.
> I don't understand if this is an issue of the new settings with
> spatialite or I'm wrong something.
> Thx,
> Andrea Peri
> qwerty àèìòù
