[mapserver-users] Incompatibility at Filter - level between mapserver 6.x and the last mapserver-dev ?
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Jun 9 10:05:42 PDT 2015
As of MapServer 7.0 FILTERS must be given using MapServer syntax - this is a regression noted in the Migration Guide, see http://mapserver.org/MIGRATION_GUIDE.html#migration. There's an OGR example right towards the top of that document. Basically:
FILTER "WHERE ([CODICE] = 107)"
FILTERITEM "CODICE"
Becomes:
PROCESSING 'NATIVE_FILTER=CODICE=107'
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
Sent: Tuesday, June 09, 2015 3:45 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Incompatibility at Filter - level between mapserver 6.x and the last mapserver-dev ?
I have just update my mapserver to the last mapserver-dev .
After this update, I see an error on the filtering.
In my mapfile the data configuration was originally this:
CONNECTION "/path-to-spatialite-db/zz_db_tematici.sqlite"
CONNECTIONTYPE OGR
DATA "IFT2009"
EXTENT 1554650.74 4678225.52 1771822.76 4924891.9
FILTERITEM "CODICE"
The log report this error:
[Tue Jun 9 10:39:46 2015].153296 msDrawMap(): rendering using
outputformat named AGGA (AGG/PNG).
[Tue Jun 9 10:39:46 2015].154698 msDrawMap(): WMS/WFS set-up and query, 0.001s
[Tue Jun 9 10:39:46 2015].262330 LayerDefaultTranslateFilter():
General error message. This data driver does not implement filter
translation support
[Tue Jun 9 10:39:46 2015].282402 msDrawMap(): Layer 239
(rt_ucs.idift.rt.107), 0.128s
[Tue Jun 9 10:39:46 2015].282550 msDrawMap(): Drawing Label Cache, 0.000s
I'm using spatialite as db.
After this error, I read this RFC:
http://www.mapserver.org/ru/development/rfc/ms-rfc-91.html
And try the new settings,
FILTER (([FILTERITEM[ = "string") AND (CODICE = 107))
but it seem don't work.
I don't understand if this is an issue of the new settings with
spatialite or I'm wrong something.
Thx,
Andrea Peri
qwerty àèìòù
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
