[mapserver-users] Incompatibility at Filter - level between mapserver 6.x and the last mapserver-dev ?
Schylberg Lars
lars.schylberg at saabgroup.com
Tue Jun 9 03:15:19 PDT 2015
It seems like You have a typing error.
FILTER "([CODICE[ = 107)"
Should be:
FILTER "([CODICE] = 107)"
/Lars
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
Sent: den 9 juni 2015 11:34
To: Eichner, Andreas - SID
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Incompatibility at Filter - level between mapserver 6.x and the last mapserver-dev ?
Thx for response.
I try this,
FILTER "(CODICE = 107)"
and also this
and removing the filteritem,
but still go in error:
The log report this:
[Tue Jun 9 11:29:53 2015].880265 LayerDefaultTranslateFilter():
General error message. This data driver does not implement filter translation support [Tue Jun 9 11:29:53 2015].955070 msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
2015-06-09 11:06 GMT+02:00 Eichner, Andreas - SID
<Andreas.Eichner at sid.sachsen.de>:
> I think you should use
> i.e. without using FILTERITEM and the leading WHERE
>> -----Ursprüngliche Nachricht-----
>> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
>> bounces at lists.osgeo.org] Im Auftrag von Andrea Peri
>> Gesendet: Dienstag, 9. Juni 2015 10:45
>> An: mapserver-users at lists.osgeo.org
>> Betreff: [mapserver-users] Incompatibility at Filter - level between
>> Hi,
>> I have just update my mapserver to the last mapserver-dev .
>> After this update, I see an error on the filtering.
>> In my mapfile the data configuration was originally this:
>> CONNECTION "/path-to-spatialite-db/zz_db_tematici.sqlite"
>> CONNECTIONTYPE OGR
>> DATA "IFT2009"
>> EXTENT 1554650.74 4678225.52 1771822.76 4924891.9
>> FILTER "WHERE ([CODICE] = 107)"
>> FILTERITEM "CODICE"
>> The log report this error:
>> [Tue Jun 9 10:39:46 2015].153296 msDrawMap(): rendering using
>> outputformat named AGGA (AGG/PNG).
>> [Tue Jun 9 10:39:46 2015].154698 msDrawMap(): WMS/WFS set-up and
>> query, 0.001s [Tue Jun 9 10:39:46 2015].262330
>> translation support [Tue Jun 9 10:39:46 2015].282402 msDrawMap():
>> Layer 239 (rt_ucs.idift.rt.107), 0.128s [Tue Jun 9 10:39:46
>> 2015].282550 msDrawMap(): Drawing Label Cache, 0.000s
>> I'm using spatialite as db.
>> After this error, I read this RFC:
>> http://www.mapserver.org/ru/development/rfc/ms-rfc-91.html
>> And try the new settings,
>> FILTER (([FILTERITEM[ = "string") AND (CODICE = 107))
>> but it seem don't work.
>> I don't understand if this is an issue of the new settings with
>> spatialite or I'm wrong something.
>> Thx,
>> Andrea Peri
>> qwerty àèìòù
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty àèìòù
