[mapserver-users] Accessing ArcSDE on secured site
Weisbender, Eric
Weisbend at WAPA.GOV
Tue Jun 9 06:16:56 PDT 2015
The error I’m getting is very vague and it is the same in the DEBUG file. After about 5 minutes of trying to connect I get the following error…
msSDELayerOpen(): SDE error. SE_connection_create(): Operation Failed. (-1)
Thanks
Eric
From: michael.smith.erdc at gmail.com [mailto:michael.smith.erdc at gmail.com]
Sent: 2015, June, 08 4:06 PM
To: Weisbender, Eric
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Accessing ArcSDE on secured site
Eric,
This could be a certificate issue if your server certificate is not a standard one. You might need to load the cert to your local cert store.
You should ruin this with shp2img on the command line and turn up the debugging level and see what errors you're actually getting.
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On Jun 8, 2015, at 4:16 PM, Weisbender, Eric <Weisbend at WAPA.GOV<mailto:Weisbend at WAPA.GOV>> wrote:
Hello,
A couple of weeks about I posted the question below and hear anything. I was wondering if it went through and if anyone had any insight.
I am trying to access ArcSDE with mapserver on a secured site that uses https:// not http. I keep getting an error saying Server Not Found. Is this even possible and if so I would welcome any help. Thanks in advance.
Eric
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150609/2bbc1c66/attachment.html>
