[mapserver-users] (no subject)
TDS
tds at tds-net.de
Thu Jun 18 06:00:03 PDT 2015
Hello Hosain,
numbers in english style:
77388 => non-decimal without points, commas, etc
77.388 => 77 full and 388 as decimals
Bye, Mathias
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 18.06.2015 um 14:49 schrieb hosain mohammadi:
> the code below is a layer in map file in this code i want create a
> query in postgis for shortestpath but a the number 77 ,388 is the
> source and target and the result create successfully but my problem
> is how insert the number ( 77, 388) in template file or insert by user
> how insert from html file
> LAYER
> CONNECTION "host=localhost dbname=network user=postgres
> password=021555 port=5432"
> CONNECTIONTYPE POSTGIS
> DATA "geom from (SELECT * from pgr_dijkstra(
> 'SELECT gid as id , source , target , cost FROM tehran' ,
> 77, 388,false , false ) a LEFT JOIN tehran b ON (a.id2 = b.gid)) AS
> foo using unique gid using srid=4326 "
> NAME "shortestpath"
> PROJECTION
> "proj=utm"
> "zone=39"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END # PROJECTION
> STATUS ON
> TEMPLATE "query"
> TILEITEM "location"
> TYPE LINE
> UNITS METERS
> CLASS
> NAME "Class (0)"
> STYLE
> COLOR 255 128 64
> SIZE 8
> WIDTH 10
> END # STYLE
> END # CLASS
> END # LAYER
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150618/e2fc0840/attachment.html>
