[mapserver-users] (no subject)
TDS tds at tds-net.de
Thu Jun 18 06:00:03 PDT 2015
Hello Hosain,
numbers in english style:
77388 => non-decimal without points, commas, etc
77.388 => 77 full and 388 as decimals
Bye, Mathias
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 18.06.2015 um 14:49 schrieb hosain mohammadi:
> the code below is a layer in map file  in this code i want create a
> query in postgis for shortestpath but a the number 77 ,388 is the
> source and target and the result create successfully but  my problem
> is how insert  the number ( 77, 388)  in template file or insert by user
> how insert from html file
> LAYER
>     CONNECTION "host=localhost   dbname=network  user=postgres
>  password=021555  port=5432"
>     CONNECTIONTYPE POSTGIS
>     DATA "geom from (SELECT  *  from pgr_dijkstra(
>                 'SELECT gid as id , source , target , cost FROM tehran' ,
> 77, 388,false , false ) a  LEFT JOIN tehran b ON (a.id2 = b.gid)) AS
> foo using unique gid using srid=4326  "
>     NAME "shortestpath"
>     PROJECTION
>       "proj=utm"
>       "zone=39"
>       "datum=WGS84"
>       "units=m"
>       "no_defs"
>     END # PROJECTION
>     STATUS ON
>     TEMPLATE "query"
>     TILEITEM "location"
>     TYPE LINE
>     UNITS METERS
>     CLASS
>       NAME "Class (0)"
>       STYLE
>         COLOR 255 128 64
>         SIZE 8
>         WIDTH 10
>       END # STYLE
>     END # CLASS
>   END # LAYER
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150618/e2fc0840/attachment.htm>
More information about the MapServer-users mailing list
