[mapserver-users] MapScriptException error
TDS
tds at tds-net.de
Thu Jun 18 22:48:49 PDT 2015
can you post the lines in that file around line 18?
Has the file correct permissions and can Apache access that file - e.g.
no restrictions like open_basedir?
Bye, Mathias
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 19.06.2015 um 07:16 schrieb ankur chitranshi:
> Dear,
> Still facing error....
> *Warning*: ms_newMapObj(): [MapServer Error]: loadSymbol(): Parsing
> error near (position):(line 29) in
> *C:\ms4w\Apache\htdocs\bhopalf\index.php* on line *18*
> *Fatal error*: Uncaught exception 'MapScriptException' with message
> 'Failed to open map file
> "C:\ms4w\Apache\htdocs\bhopalf\mapFiles\khasra.map"' in
> C:\ms4w\Apache\htdocs\bhopalf\index.php:18 Stack trace: #0
> C:\ms4w\Apache\htdocs\bhopalf\index.php(18):
> ms_newMapObj('C:\ms4w\Apache\...') #1 {main} thrown in
> On Fri, Jun 19, 2015 at 9:45 AM, TDS <tds at tds-net.de
> <mailto:tds at tds-net.de>> wrote:
> Hello,
> MapScript can't find the file. Try to use absolute path instead of
> relative path, e.g. /MyWorkingDir/mapFiles/khasra.map instead of
> mapFiles/khasra.map. Check also that on linux/posix system all is
> case sensitive.
> Bye, TDS
> 1+1=10
> Am 19.06.2015 um 06:13 schrieb ankur chitranshi:
>> while updating map server version 5.2.3 to 6.0.3, i am facing
>> bellow error,
>> *Warning*: ms_newMapObj(): [MapServer Error]: msLoadMap():
>> (mapFiles/khasra.map) in
>> *C:\ms4w\Apache\htdocs\bhopalf\index.php* on line *26*
>> message 'Failed to open map file "mapFiles/khasra.map"' in
>> C:\ms4w\Apache\htdocs\bhopalf\index.php:26 Stack trace: #0
>> C:\ms4w\Apache\htdocs\bhopalf\index.php(26):
>> ms_newMapObj('mapFiles/khasra...') #1 {main} thrown in
>> *kindly help me*
>> *thanking you
>> thanks & regards
>> Ankur Chitranshi
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> thanks & regards
> Ankur Chitranshi
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150619/db33d457/attachment.html>
