[mapserver-users] MapScriptException error
ankur chitranshi
ankuriimt at gmail.com
Thu Jun 18 23:05:03 PDT 2015
yes sure,
in line 18 my code is
$map=ms_newMapObj('C:\ms4w\Apache\htdocs\bhopalf\mapFiles\khasra.map');
and my 'khasra.map ' file code follows....
MAP
NAME "bhopal Map"
IMAGECOLOR 255 255 255
SIZE 1050 637
IMAGETYPE PNG
WEB
TEMPLATE "index.php"
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp"
END
SCALEBAR
INTERLACE ON
INTERVALS 1
LABEL
SIZE TINY
END
TRANSPARENT ON
UNITS KILOMETERS
END
LAYER
NAME "BASE"
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION ""
DATA ""
TYPE polygon
CLASSITEM "BASE"
CLASS
NAME "Data Not Available"
STYLE
COLOR 0 0 0
END
STYLE
SYMBOL "foo"
COLOR 255 0 0
END
LABEL
COLOR 145 145 145
SIZE medium
END
END
END
END
my MapServer version is 6.0.3 (MS4W 3.0.6)
thanks in advance....
On Fri, Jun 19, 2015 at 11:18 AM, TDS <tds at tds-net.de> wrote:
> Hi,
> can you post the lines in that file around line 18?
> Has the file correct permissions and can Apache access that file - e.g. no
> restrictions like open_basedir?
> Bye, Mathias
> mailto:tds at tds-net.de <tds at tds-net.de>
> 1+1=10
> You have a question? - 42 or RTFM.
> Am 19.06.2015 um 07:16 schrieb ankur chitranshi:
> Dear,
> Still facing error....
> *Warning*: ms_newMapObj(): [MapServer Error]: loadSymbol(): Parsing error
> near (position):(line 29) in *C:\ms4w\Apache\htdocs\bhopalf\index.php* on
> line *18*
> *Fatal error*: Uncaught exception 'MapScriptException' with message
> 'Failed to open map file
> "C:\ms4w\Apache\htdocs\bhopalf\mapFiles\khasra.map"' in
> C:\ms4w\Apache\htdocs\bhopalf\index.php:18 Stack trace: #0
> C:\ms4w\Apache\htdocs\bhopalf\index.php(18):
> ms_newMapObj('C:\ms4w\Apache\...') #1 {main} thrown in
> *C:\ms4w\Apache\htdocs\bhopalf\index.php* on line *18*
> On Fri, Jun 19, 2015 at 9:45 AM, TDS <tds at tds-net.de> wrote:
>> Hello,
>> MapScript can't find the file. Try to use absolute path instead of
>> relative path, e.g. /MyWorkingDir/mapFiles/khasra.map instead of
>> mapFiles/khasra.map. Check also that on linux/posix system all is case
>> sensitive.
>> Bye, TDS
>> 1+1=10
>> Am 19.06.2015 um 06:13 schrieb ankur chitranshi:
>> while updating map server version 5.2.3 to 6.0.3, i am facing bellow
>> error,
>> *Warning*: ms_newMapObj(): [MapServer Error]: msLoadMap():
>> (mapFiles/khasra.map) in *C:\ms4w\Apache\htdocs\bhopalf\index.php* on
>> line *26*
>> 'Failed to open map file "mapFiles/khasra.map"' in
>> C:\ms4w\Apache\htdocs\bhopalf\index.php:26 Stack trace: #0
>> C:\ms4w\Apache\htdocs\bhopalf\index.php(26):
>> ms_newMapObj('mapFiles/khasra...') #1 {main} thrown in
>> *C:\ms4w\Apache\htdocs\bhopalf\index.php* on line *26*
>> *kindly help me*
>> *thanking you *
>> thanks & regards
>> Ankur Chitranshi
>> mapserver-users mailing listmapserver-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapserver-users
> thanks & regards
> Ankur Chitranshi
thanks & regards
Ankur Chitranshi
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150619/b8db9572/attachment-0001.html>
