[mapserver-users] Odd warning in WFS GetCapabilities ~ what's missing in the config?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Mar 12 06:08:57 PDT 2015
On 2015-03-12 9:12 AM, Passmore, James H. wrote:
> I have a MapServer version 6.4.1 service set-up and was looking at the WFS GetCapabilities response:
> http://194.66.252.155/cgi-bin/BGS_OGE_Bedrock_and_Surface_Geology_in2/ows?service=WFS&request=GetCapabilities&
> All my FeatureTypes have the following warning:
> WARNING: Mandatory mapfile parameter: (at least one of) MAP.PROJECTION, LAYER.PROJECTION or wfs/ows_srs metadata was missing in this context.
> The WFS is working though as far as I can see, for example, I get features when loading in QGIS.
> Is this a bug or have I got something wrong in the config?
> MAP.PROJECTION is set as:
> MAP
> CONFIG "PROJ_LIB" "C:/.../gisinternals/bin/proj/SHARE"
> CONFIG "MS_ERRORFILE" "C:/.../OGE2/ms_error.log"
> CONFIG "PGEO_DRIVER_TEMPLATE" "DRIVER=Microsoft Access Driver (*.mdb, *.accdb);DBQ=%s"
> CONFIG "OGR_SKIP" "ODBC"
> EXTENT -8.7 49.8 1.8 60.9
> PROJECTION
> #Default service projection
> "init=epsg:4326"
> END
> LAYER.PROJECTION (for example for GE.GeologicFault.BGS.EN.1M.Surface) is set as:
> LAYER
> NAME GE.GeologicFault.BGS.EN.1M.Surface
> EXTENT -8.01697 49.9678 0.715821 60.8368
> PROJECTION
> "init=epsg:4326"
> END
> In addition I have:
> WEB
> METADATA
> "OWS_SRS" "CRS:84 EPSG:27700 EPSG:3034 EPSG:4258 EPSG:4326"
> and:
> LAYER
> METADATA
> "OWS_EXTENT" "-8.01697 49.9678 0.715821 60.8368"
> "WFS_OWS" "EPSG:4326"
> Thanks
> James Passmore
> GIS and WWW Specialist
> British Geological Survey,
> Environmental Science Centre,
> KEYWORTH,
> United Kingdom,
> NG12 5GG
> Linked Data (vCard):http://data.bgs.ac.uk/ref/BritishGeologicalSurvey
> w3w:http://w3w.co/firmly.legs.craftsmen
You are missing the required parameter VERSION in your request. If I
add it to your request I get no warnings:
http://194.66.252.155/cgi-bin/BGS_OGE_Bedrock_and_Surface_Geology_in2/ows?service=WFS&request=GetCapabilities&VERSION=1.0.0
(hello from 'across the big pond')
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
