[mapserver-users] Is there a way to convert a QGIS layout into a ".map" file?
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Mar 18 01:15:36 PDT 2015
There is this plugin http://plugins.qgis.org/plugins/rt_mapserver_exporter/
and old documentation http://docs.qgis.org/1.8/en/docs/user_manual/plugins/plugins_mapserver_export.html
Unfortunately the plugin makes mapfiles which were usable as-is with Mapserver 5.x but not since that. It also creates mapfiles which I do not like a lot because it is lazy with PROJECTION blocks etc. but that is at least partly matter of taste. But if you know how to write valid mapfiles for Mapserver v. 6.x and above then that plugin does make usable templates which can save time. It would be nice to get that plugin up-to-date.
Other alternatives which do not help with QGIS styles but are worth having a look: http://scribeui.org/ and http://gisinternals.com/mapmanager.html
-Jukka Rahkonen-
Michael Kleih wrote:
> Hello all,
> I am using Mapserver since nearly 20 years and like it a lot.
> QGIS is getting better and better and it would be nice to layout a map in QGIS and then convert it to a ".map"-file to be used with Mapserver.
> Does anybody know if this is possible?
> Thanks to all,
> Michael
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
