[mapserver-users] Is there a way to convert a QGIS layout into a ".map" file?
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Mar 18 10:50:37 PDT 2015
I've wondered if we could/should pull the plug-in into the MapServer project itself.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen Jukka (MML)
Sent: Wednesday, March 18, 2015 3:16 AM
To: Michael Kleih; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Is there a way to convert a QGIS layout into a ".map" file?
There is this plugin http://plugins.qgis.org/plugins/rt_mapserver_exporter/
and old documentation http://docs.qgis.org/1.8/en/docs/user_manual/plugins/plugins_mapserver_export.html
Unfortunately the plugin makes mapfiles which were usable as-is with Mapserver 5.x but not since that. It also creates mapfiles which I do not like a lot because it is lazy with PROJECTION blocks etc. but that is at least partly matter of taste. But if you know how to write valid mapfiles for Mapserver v. 6.x and above then that plugin does make usable templates which can save time. It would be nice to get that plugin up-to-date.
Other alternatives which do not help with QGIS styles but are worth having a look: http://scribeui.org/ and http://gisinternals.com/mapmanager.html
-Jukka Rahkonen-
Michael Kleih wrote:
> Hello all,
> I am using Mapserver since nearly 20 years and like it a lot.
> QGIS is getting better and better and it would be nice to layout a map in QGIS and then convert it to a ".map"-file to be used with Mapserver.
> Does anybody know if this is possible?
> Thanks to all,
> Michael
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
