[mapserver-users] Is there a way to convert a QGIS layout into a ".map" file?
b.j.kobben at utwente.nl
Thu Mar 19 00:38:17 PDT 2015
I am all for QGIS-MapServer integration!
As an aside, getting QGIS styling per se into MapServer can of course also
be done through SLD: QGIS SLD export is pretty good -- although of course
will only give you layer styles, not a full map setup.
Barend Köbben
On 19-03-15 00:10, "Jeff McKenna" <jmckenna at gatewaygeomatics.com> wrote:
>I wonder the same, especially seeing that plugin code living on GitHub.
> Think of how QGIS has become the frontend for GRASS, it could(should!)
>be the frontend for MapServer.
>There is definitely huge momentum in the QGIS community (I've even been
>asked to attend their first QGIS conference, and followup dev meeting,
>in May). I can imagine/dream of a joint MapServer/QGIS code sprint,
>totally funded (as a few of the OpenLayers3 sprints were) happening
>someday. Would be amazing.
>-jeff
>On 2015-03-18 2:50 PM, Lime, Steve D (MNIT) wrote:
>> I've wondered if we could/should pull the plug-in into the MapServer
>>project itself.
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org
>>[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen
>>Jukka (MML)
>> Sent: Wednesday, March 18, 2015 3:16 AM
>> To: Michael Kleih; mapserver-users at lists.osgeo.org
>> Subject: Re: [mapserver-users] Is there a way to convert a QGIS layout
>>into a ".map" file?
>> Hi,
>> There is this plugin
>>http://plugins.qgis.org/plugins/rt_mapserver_exporter/
>> and old documentation
>>http://docs.qgis.org/1.8/en/docs/user_manual/plugins/plugins_mapserver_ex
>>port.html
>> Unfortunately the plugin makes mapfiles which were usable as-is with
>>Mapserver 5.x but not since that. It also creates mapfiles which I do
>>not like a lot because it is lazy with PROJECTION blocks etc. but that
>>is at least partly matter of taste. But if you know how to write valid
>>mapfiles for Mapserver v. 6.x and above then that plugin does make
>>usable templates which can save time. It would be nice to get that
>>plugin up-to-date.
>> Other alternatives which do not help with QGIS styles but are worth
>>having a look: http://scribeui.org/ and
>>http://gisinternals.com/mapmanager.html
>> -Jukka Rahkonen-
>> Michael Kleih wrote:
>>> Hello all,
>>> I am using Mapserver since nearly 20 years and like it a lot.
>>> QGIS is getting better and better and it would be nice to layout a map
>>>in QGIS and then convert it to a ".map"-file to be used with Mapserver.
>>> Does anybody know if this is possible?
>>> Thanks to all,
>>> Michael
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>Jeff McKenna
>MapServer Consulting and Training Services
>http://www.gatewaygeomatics.com/
