[mapserver-users] RE Mapserver 7 make error
Even Rouault
even.rouault at spatialys.com
Tue May 5 06:33:18 PDT 2015
Le mardi 05 mai 2015 15:26:16, Jeff McKenna a écrit :
> Hi Steve,
> I do note that I use cairo-1.12.14 for both my MS4W and Ubuntu builds.
> And I also note that compiling cairo into your MapServer will indeed
> test your patience and sanity :)
> Finding the "elusive" and magical version of cairo that works perfectly
> with GDAL and MapServer and libPoppler is quite fun.
Jeff,
GDAL doesn't depend on cairo directly. Poppler might depend on cairo, but I
believe it is only an optional dependency (maybe for some utilities or unit
tests). I've just checked that my system libpoppler doesn't actually depend on
cairo. And pdftoppm doesn't either. So you could probably build poppler
without cairo to simplify the dependency equations ;-)
Even
> -jeff
> > Any hint on what can I do about that Cairo error when compiling mapserv?
> > Thank you
> > *Steve Toutant/INSPQ/SSSS*
> > 2015-05-01 15:11
> > A
> > mapserver-users at lists.osgeo.org
> > cc
> > Objet
> > I'm compiling MS7 on Centos 6.5. I get an error running make
> > make
> > Scanning dependencies of target mapserver
> > [ 0%] Building C object CMakeFiles/mapserver.dir/fontcache.c.o
> > [ 1%] Building C object CMakeFiles/mapserver.dir/cgiutil.c.o
> > [ 2%] Building C object CMakeFiles/mapserver.dir/mapgeos.c.o
> > [ 2%] Building C object CMakeFiles/mapserver.dir/maporaclespatial.c.o
> > [ 3%] Building C object CMakeFiles/mapserver.dir/mapsearch.c.o
> > [ 4%] Building C object CMakeFiles/mapserver.dir/mapwms.c.o
> > [ 4%] Building C object CMakeFiles/mapserver.dir/classobject.c.o
> > [ 5%] Building C object CMakeFiles/mapserver.dir/mapgml.c.o
> > [ 6%] Building C object CMakeFiles/mapserver.dir/mapoutput.c.o
> > [ 6%] Building C object CMakeFiles/mapserver.dir/mapwmslayer.c.o
> > [ 7%] Building C object CMakeFiles/mapserver.dir/layerobject.c.o
> > [ 8%] Building C object CMakeFiles/mapserver.dir/mapgraticule.c.o
> > [ 8%] Building C object CMakeFiles/mapserver.dir/mapows.c.o
> > [ 9%] Building C object CMakeFiles/mapserver.dir/mapservutil.c.o
> > [ 10%] Building C object CMakeFiles/mapserver.dir/mapxbase.c.o
> > [ 10%] Building C object CMakeFiles/mapserver.dir/maphash.c.o
> > [ 11%] Building C object CMakeFiles/mapserver.dir/mapowscommon.c.o
> > [ 11%] Building C object CMakeFiles/mapserver.dir/mapshape.c.o
> > [ 12%] Building C object CMakeFiles/mapserver.dir/mapxml.c.o
> > [ 13%] Building C object CMakeFiles/mapserver.dir/mapbits.c.o
> > [ 13%] Building C object CMakeFiles/mapserver.dir/maphttp.c.o
> > [ 14%] Building C object CMakeFiles/mapserver.dir/mapparser.c.o
> > [ 15%] Building C object CMakeFiles/mapserver.dir/mapstring.c.o
> > [ 15%] Building C object CMakeFiles/mapserver.dir/mapxmp.c.o
> > [ 16%] Building C object CMakeFiles/mapserver.dir/mapcairo.c.o
> > /opt/geomatique/src/mapserver/mapcairo.c: In function âms2cairo_compopâ:
> > /opt/geomatique/src/mapserver/mapcairo.c:809: erreur:
> > âCAIRO_OPERATOR_MULTIPLYâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:809: erreur: (Each undeclared
> > identifier is reported only once
> > /opt/geomatique/src/mapserver/mapcairo.c:809: erreur: for each function
> > it appears in.)
> > /opt/geomatique/src/mapserver/mapcairo.c:811: erreur:
> > âCAIRO_OPERATOR_SCREENâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:813: erreur:
> > âCAIRO_OPERATOR_OVERLAYâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:815: erreur:
> > âCAIRO_OPERATOR_DARKENâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:817: erreur:
> > âCAIRO_OPERATOR_LIGHTENâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:819: erreur:
> > âCAIRO_OPERATOR_COLOR_DODGEâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:821: erreur:
> > âCAIRO_OPERATOR_COLOR_BURNâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:823: erreur:
> > âCAIRO_OPERATOR_HARD_LIGHTâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:825: erreur:
> > âCAIRO_OPERATOR_SOFT_LIGHTâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:827: erreur:
> > âCAIRO_OPERATOR_DIFFERENCEâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:829: erreur:
> > âCAIRO_OPERATOR_EXCLUSIONâ undeclared (first use in this function)
> > make[2]: *** [CMakeFiles/mapserver.dir/mapcairo.c.o] Erreur 1
> > make[1]: *** [CMakeFiles/mapserver.dir/all] Erreur 2
> > make: *** [all] Erreur 2
> > I do have cairo and cairo-devel installed (1.8.8-3.1.el6).
> > How can I fix this?
> > Thanks you
http://www.spatialys.com
