[mapserver-users] RE Setting up many vitual hosts
Steve.Toutant at inspq.qc.ca
Wed May 27 07:08:43 PDT 2015
easy yes...
I suggest you read this, so you can choose your preferred method to do
what you want
http://mapserver.org/ogc/wms_server.html#changing-the-online-resource-url
we use this method
http://mapserver.org/ogc/wms_server.html#wrapper-script-unix
But I just read that it is not recommended.....
"Mérette,Jacques (Consultant)" <Jacques.Merette-c at mtq.gouv.qc.ca>
2015-05-27 09:47
A
"'Steve.Toutant at inspq.qc.ca'" <Steve.Toutant at inspq.qc.ca>
cc
"'mapserver-users at lists.osgeo.org'" <mapserver-users at lists.osgeo.org>,
"mapserver-users-bounces at lists.osgeo.org"
<mapserver-users-bounces at lists.osgeo.org>
Objet
RE: RE [mapserver-users] Setting up many vitual hosts
Bonjour Steve,
Excellent?.
I want to have only one instance of mapserver bit many virtual hosts on
Apache. Each virtual host will have its own ?mapfile? (that is what I mean
by ?add my data in a new virtual host?). Following my understanding, it
should be quite easy?.
MErci!
J.
From: Steve.Toutant at inspq.qc.ca [mailto:Steve.Toutant at inspq.qc.ca]
Sent: 27 mai 2015 08:27
To: Mérette, Jacques (Consultant)
Cc: 'mapserver-users at lists.osgeo.org';
Subject: RE [mapserver-users] Setting up many vitual hosts
Jacques it is possible to create many virtual host on apache, but what do
you mean by "add my data in a new virtual host". The virtual hosts can use
the same mapserver....Unless you want to have several instance of
mapserver...?
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2015-05-26 18:11
A
cc
Objet
I?m installing Mapserver for the first time. The demo works fine on RHEL
but I would like to add my data in a new virtual host. Is it possible to
set up many vitual hosts on Apache/Mapserver?
Merci!
Jacques Mérette
Architecte technologique
Division des infrastructures technologiques
Service des infrastructures technologiques appliquées aux opérations
Direction des technologies de l?information
Ministère des Transports du Québec
Tél: 418-643-5350 # 24685
jacques.merette-c at mtq.gouv.qc.ca
Boîte commune : Architectes-Technologique._C-DTI at mtq.gouv.qc.ca
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150527/ab6c6db9/attachment-0001.html>
