[mapserver-users] RE Setting up many vitual hosts
Steve.Toutant at inspq.qc.ca
Wed May 27 07:13:27 PDT 2015
And if you need to do some stuff before making the request, a wrapper
might a good solution
http://mapserver.org/ogc/mapscript.html#php-example
it could be plain php also instead of mapscript.
And you can send the ows parameters as POST
Really there are several ways to do what you want
"Mérette,Jacques (Consultant)" <Jacques.Merette-c at mtq.gouv.qc.ca>
2015-05-27 09:47
A
"'Steve.Toutant at inspq.qc.ca'" <Steve.Toutant at inspq.qc.ca>
cc
"'mapserver-users at lists.osgeo.org'" <mapserver-users at lists.osgeo.org>,
"mapserver-users-bounces at lists.osgeo.org"
<mapserver-users-bounces at lists.osgeo.org>
Objet
RE: RE [mapserver-users] Setting up many vitual hosts
Bonjour Steve,
Excellent?.
I want to have only one instance of mapserver bit many virtual hosts on
Apache. Each virtual host will have its own ?mapfile? (that is what I mean
by ?add my data in a new virtual host?). Following my understanding, it
should be quite easy?.
MErci!
J.
From: Steve.Toutant at inspq.qc.ca [mailto:Steve.Toutant at inspq.qc.ca]
Sent: 27 mai 2015 08:27
To: Mérette, Jacques (Consultant)
Cc: 'mapserver-users at lists.osgeo.org';
Subject: RE [mapserver-users] Setting up many vitual hosts
Jacques it is possible to create many virtual host on apache, but what do
you mean by "add my data in a new virtual host". The virtual hosts can use
the same mapserver....Unless you want to have several instance of
mapserver...?
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2015-05-26 18:11
A
cc
Objet
I?m installing Mapserver for the first time. The demo works fine on RHEL
but I would like to add my data in a new virtual host. Is it possible to
set up many vitual hosts on Apache/Mapserver?
Merci!
Jacques Mérette
Architecte technologique
Division des infrastructures technologiques
Service des infrastructures technologiques appliquées aux opérations
Direction des technologies de l?information
Ministère des Transports du Québec
Tél: 418-643-5350 # 24685
jacques.merette-c at mtq.gouv.qc.ca
Boîte commune : Architectes-Technologique._C-DTI at mtq.gouv.qc.ca
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150527/5efc65d8/attachment.html>
