[mapserver-users] Issue adding mapcache into AutoCAD Civil 3D via WMS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri May 29 08:08:37 PDT 2015
Whenever I have problems with WMS or cache requests, I always start with
the actual request (example: if QGIS has problems, either get the full
WMS request through QGIS logs, or check the Apache logs on the server).
Then I would paste that request in a browser window and see the actual
response from the MapServer server.
You might actually even paste the full WMS request here for the
community to analyze.
I bet that would help you diagnose your problem.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2015-05-29 11:52 AM, Mark Volz wrote:
> Hello,
> I am having trouble loading the MapCache WMS layers into AutoCAD Civil
> 3D. I set the projection to my county coordinates, which is what
> MapCache uses. Next I loaded the MapCache WMS server. Unfortunately I
> got an error:
> There was a problem adding data to Map.
> Failed to get bands data.
> The HTTP request could not be understood by the server due to malformed
> syntax.
> I was able to load other WMS layers in AutoCAD.
> In ArcMap, I initially received an error that there is no <grid> with
> suitable srs found for the layer. This issue was quickly resolved when
> I changed the coordinate system to county coordinates?
> Questions:
> If possible, What needs to be done so that I can load mapcache layers
> into AutoCAD Civil 3D? Do I just need to break down and cache the WGS
> 84 grid?
> Thank You
> Sincerely,
> *Mark Volz*
> mapserver-users at lists.osgeo.org
