[mapserver-users] Issue adding mapcache into AutoCAD Civil 3D via WMS
Ben Madin
ben at ausvet.com.au
Fri May 29 20:07:29 PDT 2015
FWIW,
Firebug (Firefox add-in) or similar tools are invaluable for getting the request string if you are using openlayers.
cheers
Ben
> On 2015-05-29, at 23:08 , Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Whenever I have problems with WMS or cache requests, I always start with the actual request (example: if QGIS has problems, either get the full WMS request through QGIS logs, or check the Apache logs on the server).
> Then I would paste that request in a browser window and see the actual response from the MapServer server.
> You might actually even paste the full WMS request here for the community to analyze.
> I bet that would help you diagnose your problem.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 2015-05-29 11:52 AM, Mark Volz wrote:
>> Hello,
>> I am having trouble loading the MapCache WMS layers into AutoCAD Civil
>> 3D. I set the projection to my county coordinates, which is what
>> MapCache uses. Next I loaded the MapCache WMS server. Unfortunately I
>> got an error:
>> There was a problem adding data to Map.
>> Failed to get bands data.
>> The HTTP request could not be understood by the server due to malformed
>> syntax.
>> I was able to load other WMS layers in AutoCAD.
>> In ArcMap, I initially received an error that there is no <grid> with
>> suitable srs found for the layer. This issue was quickly resolved when
>> I changed the coordinate system to county coordinates?
>> Questions:
>> If possible, What needs to be done so that I can load mapcache layers
>> into AutoCAD Civil 3D? Do I just need to break down and cache the WGS
>> 84 grid?
>> Thank You
>> Sincerely,
>> *Mark Volz*
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Ben Madin
t : +61 8 6102 5535
m : +61 448 887 220
e : ben at ausvet.com.au
AusVet Animal Health Services
Western Australia
AusVet's website: http://www.ausvet.com.au
This transmission is for the intended addressee only and is confidential information. If you have received this transmission in error, please delete it and notify the sender. The contents of this email are the opinion of the writer only and are not endorsed by AusVet Animal Health Services unless expressly stated otherwise. Although AusVet uses virus scanning software we do not accept liability for viruses or similar in any attachments. Thanks for reading.
