[mapserver-users] How avoid overlapping of label between two distinct layers
thomas bonfort
thomas.bonfort at gmail.com
Tue Aug 9 05:10:34 PDT 2016
Mapserver will prevent label coliding by default unless you force it
to do otherwise. I suspect that in your case one of the layers is
either not using a labelcache, set to FORCE, or is a client WMS layer
for which your own mapserver has no control/knowledge of label
positions.
thomas
On 9 August 2016 at 14:06, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> I need to avoid the overlapping of labels between two layers.
> To do this I try to set the BUFFER option in both layers, but I see it
> seem don't work as I expected.
> Perhaps the buffer is working only for label of same layers ?
> This is a sample of actual overlapping:
> http://www502.regione.toscana.it/ows2/com.rt.wms.RTmap/wms?map=owscacciapesca&version=1.3.0&map_resolution=91&TRANSPARENT=true&LAYERS=rt_cacciapesca.sottoambito_atc_2015.rt%2Crt_cacciapesca.atc_2015.rt&STYLES=default%2Cdefault&CRS=EPSG%3A25832&SERVICE=WMS&REQUEST=GetMap&FORMAT=image%2Fpng&BBOX=672896.00367533,4847223.6202292,680026.94491189,4849534.2528872&WIDTH=824&HEIGHT=267
> In both layers I set:
> LABELCACHE on
> LAYER
> CLASS
> LABEL
> TEXT 'Sottoambito [sottoambit]'
> TYPE TRUETYPE
> BUFFER 5
> Thx.
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
