[mapserver-users] problem in wms service
Ahmet Temiz ahmettemiz88 at gmail.com
Tue Aug 16 01:37:00 PDT 2016
thank you ,
I noticed later I have missed specifying host in CONNECTION <  CONNECTION
"host=localhost  ....
Do you say map.extent is redundant code and  BBOX is doing same ?
regards
On Tue, Aug 16, 2016 at 10:37 AM, Yves Jacolin <yves.jacolin at camptocamp.com>
wrote:
> Ok, I suppose that your working test shows something in the picture?
> I suggest to enable log in your mapfile and check it after running again
> your
> not working example.
> "map.extent=2588830.423584977+4061255.6481961836+54
> 26172.9135307195+5382087.496964029" in your request should not be useful.
> Sorry no more idea here. Maybe the log will show you something weird.
> Y.
> On Tuesday, August 16, 2016 10:20:43 Ahmet Temiz wrote:
> > thank you
> > it is png file.
> > $display out.png returns blank image.
> > On Tue, Aug 16, 2016 at 10:10 AM, Yves Jacolin <
> > wrote:
> > > On Tuesday, August 16, 2016 10:07:40 Ahmet Temiz wrote:
> > > > Hi,
> > > > I am testing my wms, postgis layer it works with QUERY_STRING but not
> > > > displays anything with curl and QGIS.
> > > > ** It works
> > > > mapserv -nh
> > > > "QUERY_STRING=map=/var/www/ms_map/jeo.map&SERVICE=WMS&
> > > VERSION=1.1.1&REQUEST=
> > > > GetMap&map.extent=2588830.423584977+4061255.6481961836+
> > > 5426172.9135307195+53
> > > > 82087.496964029&LAYERS=jeo&STYLES=&SRS=EPSG:3857&BBOX=
> > > 2588830.423584977,4061
> > > > 255.6481961836,5426172.9135307195,5382087.496964029&
> > > WIDTH=1160&HEIGHT=540&FO
> > > > RMAT=image/png"
> > > > ** it doesn't work
> > > > curl --trace -i -X GET -H "Content-Type: image/png" "
> > > > http://localhost/cgi-bin/mapserv?map=/var/www/ms_map/
> > > jeo.map&SERVICE=WMS&VER
> > > > SION=1.1.1&REQUEST=GetMap&map.extent=2588830.423584977+
> > > > 26172.9135307195+5382087.496964029&LAYERS=jeo&STYLES=&
> > > SRS=EPSG:3857&BBOX=258
> > > > 8830.423584977,4061255.6481961836,5426172.9135307195,
> > > 5382087.496964029&WIDTH
> > > > =1160&HEIGHT=540&FORMAT=image/png"
> > > > Can you tell me what the likely reasons are?
> > > > regards
> > > Hello,
> > > Does out.png is a png file or a text file with an error message in it?
> If
> > > so,
> > > what is this message? If it is not a png file, is it the mapserv cgi
> file?
> > > Y.
> > > Responsable Formation et Support
> > > Camptocamp France SAS
> > > Savoie Technolac, BP 352
> > > 73377 Le Bourget du Lac, Cedex
> > > Tel (France) : +33 4 58 48 20 43 (new !)
> > > Tel (Suisse) : +41 21 619 10 43
> > > Mob. : +33 6 18 75 42 21
> > > Fax : 04 79 70 15 81
> > > Mail : yves.jacolin at camptocamp.com
> > > http://www.camptocamp.com
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem  Dairesi Başkanlığı-CBS Grubu
________________________
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160816/0a1cdca6/attachment.htm>
More information about the MapServer-users mailing list
